Question Issue with Georgian Unicode letter "რ" ("R").
- dd3f36e0c1660ab2487041ac
- Banned
14 years 6 months ago - 14 years 6 months ago #109177
by dd3f36e0c1660ab2487041ac
hi
have installed and running Kunena. anything is fine as far, EXCEPT one thing - i'm from Georgia (the country, not US state) and need to use georgian alphabet = unicode, nothing unusual.
but if somewhere in category names or subjecs i use gerogian letter "r" (that's "რ" written natively as i need), then links are no more working.
all other letters have no issues, have tested.
surely it's impossible to use the forum with this issue. i have tried different Joomla installations (all versions 1.7). Joomla self has no problems with.
any ideas how to solve? or whatever
thanks for help
thanks for help
Last edit: 14 years 6 months ago by sozzled. Reason: minor edit/spelling in subject
14 years 6 months ago #109178
by 810
Replied by 810 on topic Re: Issue with Gerogian Unicode letter "რ" ("R").
can you insert the kunena report here.
regards 810
regards 810
- Banned
14 years 6 months ago #109256
Replied by dd3f36e0c1660ab2487041ac on topic Re: Issue with Gerogian Unicode letter "რ" ("R").
hi 810, thanks for the answer.
i will attach the TXT file including the config file from fresh install of Joomla-1.7.1 + Kunena-1.7 (both just downloaded). server = windows + xampp(not old version)
generally have no other issues with things. yet
so have tested in many ways - by enbling UTF-support in Kunena the problem occurs and vice versa.
just wo UTF the link are less seo friendly... ok, possible to live with this
yes, thats actual ONLY for georgian letter "R" = "რ" (other special signs have not tested yet)
for the refference the whole alphabet(33 letters):
ა ბ გ დ ე ვ ზ თ ი კ ლ მ ნ ო პ ჟ ...> რ <... ს ტ უ ფ ქ ღ ყ შ ჩ ც ძ წ ჭ ხ ჯ ჰ
unfortunately im not developer, can only read/modify the code in some cases, but thats over my skills(
Attachment not found
14 years 6 months ago #109845
by 810
Please try to disable some plugins. There seems to be a plugin issue.
regards 810
regards 810
- Banned
14 years 6 months ago #109873
hi 810
I just now gone crazy:
* Win 2k3 (clean, healty)
* XAMPP 1.7.4
* Joomla 1.7.2 (latest) - fresh test-install, nothing changed)
* Kunena 1.7.0_b5135 (latest) - same, added only 'this' f... f... funny "რ"(R) as subject.
AND(!) disabled + uninstalled ANYTHING in joomla, regardless Admin/Site/System/Non-System/components/plugins, JUST COMPLETELY ANYTHING, well except few - just to show up Kunena.
Did it absolutely hardcore, and was funny
result: Kunena behaves in the same way - UTF disabled = OK, UTF enabled = no way.
all this - just to be sure.
there IS something wrong, but im not big developer and have no idea what exactly
on Main-Site i have simply turned off UTF support in Kunena and anything goes fine so far... and i will leave as is - have now much more problems to solve and do not need to fight windmills
(i mean myself)
anyway, thanks for attention)
I'll check sometimes if this is solved in future versions of Kunena, then report here.
regards
* XAMPP 1.7.4
regards
14 years 6 months ago - 14 years 6 months ago #109882
by 810
ok, i found a solution for the moment:
open components\com_kunena\router.php line:101
and add all gerogion letters after:
like:
regards 810
return JString::trim ( preg_replace ( array ('/\s+/', '/
like:
return JString::trim ( preg_replace ( array ('/\s+/', '/[\$\&\რ\+\,\/\:\;\=\?\@\'\"\<\>\#\%\{\}\|\\\^\~\[\]\`\.]/' ), array ('-', '' ), $str ) );
regards 810
Last edit: 14 years 6 months ago by 810.
Time to create page: 0.228 seconds
