Question Issue with Georgian Unicode letter "რ" ("R").
14 years 6 months ago - 14 years 6 months ago #109177 by dd3f36e0c1660ab2487041ac
hi
have installed and running Kunena. anything is fine as far, EXCEPT one thing - i'm from Georgia (the country, not US state) and need to use georgian alphabet = unicode, nothing unusual.
but if somewhere in category names or subjecs i use gerogian letter "r" (that's "რ" written natively as i need), then links are no more working.
all other letters have no issues, have tested.
surely it's impossible to use the forum with this issue. i have tried different Joomla installations (all versions 1.7). Joomla self has no problems with.
any ideas how to solve? or whatever
thanks for help
Last edit: 14 years 6 months ago by sozzled. Reason: minor edit/spelling in subject
14 years 6 months ago #109178 by 810
can you insert the kunena report here.
regards 810
14 years 6 months ago #109256 by dd3f36e0c1660ab2487041ac
hi 810, thanks for the answer.
i will attach the TXT file including the config file from fresh install of Joomla-1.7.1 + Kunena-1.7 (both just downloaded). server = windows + xampp(not old version)
generally have no other issues with things. yet :)
Attachment not found
so have tested in many ways - by enbling UTF-support in Kunena the problem occurs and vice versa.
just wo UTF the link are less seo friendly... ok, possible to live with this :)
yes, thats actual ONLY for georgian letter "R" = "რ" (other special signs have not tested yet)
for the refference the whole alphabet(33 letters):
ა ბ გ დ ე ვ ზ თ ი კ ლ მ ნ ო პ ჟ ...> რ <... ს ტ უ ფ ქ ღ ყ შ ჩ ც ძ წ ჭ ხ ჯ ჰ
unfortunately im not developer, can only read/modify the code in some cases, but thats over my skills(
14 years 6 months ago #109845 by 810
Please try to disable some plugins. There seems to be a plugin issue.
regards 810
14 years 6 months ago #109873 by dd3f36e0c1660ab2487041ac
hi 810
I just now gone crazy: :)
* Win 2k3 (clean, healty)
* XAMPP 1.7.4
* Joomla 1.7.2 (latest) - fresh test-install, nothing changed)
* Kunena 1.7.0_b5135 (latest) - same, added only 'this' f... f... funny "რ"(R) as subject.
AND(!) disabled + uninstalled ANYTHING in joomla, regardless Admin/Site/System/Non-System/components/plugins, JUST COMPLETELY ANYTHING, well except few - just to show up Kunena.
Did it absolutely hardcore, and was funny :)
result: Kunena behaves in the same way - UTF disabled = OK, UTF enabled = no way.
all this - just to be sure.
there IS something wrong, but im not big developer and have no idea what exactly :(
on Main-Site i have simply turned off UTF support in Kunena and anything goes fine so far... and i will leave as is - have now much more problems to solve and do not need to fight windmills :) (i mean myself)
anyway, thanks for attention)
I'll check sometimes if this is solved in future versions of Kunena, then report here.
regards
14 years 6 months ago - 14 years 6 months ago #109882 by 810
ok, i found a solution for the moment:
open components\com_kunena\router.php line:101
and add all gerogion letters after:
return JString::trim ( preg_replace ( array ('/\s+/', '/
like:
return JString::trim ( preg_replace ( array ('/\s+/', '/[\$\&\რ\+\,\/\:\;\=\?\@\'\"\<\>\#\%\{\}\|\\\^\~\[\]\`\.]/' ), array ('-', '' ), $str ) );
regards 810
Last edit: 14 years 6 months ago by 810.
Time to create page: 0.230 seconds
