Important Need help menu issue K 1.6 and upgrading to 1.7
15 years 1 month ago #109034 by dirkovision
Hi all,
(hope this is the good topic)
please help volunteer webmaster
We need help with K 1.6.4 menu issue and -before or after- upgrading to 1.7
tref.eu/index.php/forum/recent.html
used to be visible, but disappeared see picture.
English or Dutch.
thanks in advance
dirko
hungary
15 years 1 month ago #109042 by xillibit
I advise you to upgrade to Kunena 1.6.5. Can-you post here your Kunena report configuration settings ?
The following user(s) said Thank You: dirkovision
15 years 1 month ago #109045 by dirkovision
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Disabled | FTP layer: Enabled |
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 128M
Joomla default template details : it_icemag | author: IceTheme | version: 1.0 | creationdate: 01/08/09
Kunena default template details : Evolution Red K1.6 Template | author: TemplateKunena Team | version: 1.6.2 | creationdate: 2011-01-23
Third-party components: UddeIm 2.4
Plugins: System - Mootools Upgrade: Enabled | System - Mootools12: Disabled | Kunena Discuss 1.6.4
Modules: Kunena Login 1.6.2
15 years 1 month ago - 15 years 1 month ago #109047 by dirkovision
Thanks, xillibit ! we just updated to 1.6.5 but no change.
Third-party components: UddeIm 2.5
Last edit: 15 years 1 month ago by dirkovision. Reason: error solved
15 years 1 month ago #109048 by dirkovision
I think i made it by step by step with translator following the manual here.
now take a look..!! Thanks very very much.!!
dirko
15 years 1 month ago #109150 by Matias
You seem to have some issues with Kunena menu structure. There's no way the menu can show up, because of Kunena Menu doesn't have 1st level item of Kunena / Entry Page. Recreating the menu should help, but after that you need to do something to the item tref-webcafe in your main menu.
Can someone help further?
Time to create page: 0.162 seconds
