Bug [Problem assumed resolved - no response from user] 200 OK error when deleting posts
15 years 1 month ago #108583 by MisterAegir
Hey all,
I was wondering if you could help me in regards to a niggling problem I have with the apache mod_rewrite when it comes to Kunena.
Specifically, everything loads fine, I can post threads, move them, sticky etc all the normal features yet when I come to delete something on Kunena I get the following error:
OK
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, [no address given] and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
HTTP/1.1 200 OK Date: Thu, 06 Oct 2011 22:24:47 GMT Server: Apache/2.2.17 (Unix) FrontPage/5.0.2.2635 X-Powered-By: PHP/5.2.17 P3P: CP="NOI ADM DEV PSAi COM NAV OUR OTRo STP IND DEM" Expires: Mon, 1 Jan 2001 00:00:00 GMT Cache-Control: post-check=0, pre-check=0 Pragma: no-cache Last-Modified: Thu, 06 Oct 2011 22:24:48 GMT Keep-Alive: timeout=5, max=199 Connection: Keep-Alive Transfer-Encoding: chunked Content-Type: text/html; charset=utf-8 11ed8
As it stands, my .htaccess file is as follows
Options +FollowSymLinks # #mod_rewrite in use RewriteEngine On RewriteCond %{QUERY_STRING} mosConfig_[a-zA-Z_]{1,21}(=|\%3D) [OR] RewriteCond %{QUERY_STRING} base64_encode[^(]*\([^)]*\) [OR] RewriteCond %{QUERY_STRING} (<|%3C)([^s]*s)+cript.*(>|%3E) [NC,OR] RewriteCond %{QUERY_STRING} GLOBALS(=|\[|\%[0-9A-Z]{0,2}) [OR] RewriteCond %{QUERY_STRING} _REQUEST(=|\[|\%[0-9A-Z]{0,2}) RewriteRule . /index.php [F] RewriteBase / RewriteRule ^/index\.php$ - [L] RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}] RewriteCond %{REQUEST_URI} !^/index\.php RewriteCond %{REQUEST_URI} (/[^.]*|\.(php|html?|feed|pdf|raw))$ [NC] RewriteCond %{REQUEST_FILENAME} !-f RewriteCond %{REQUEST_FILENAME} !-d RewriteRule . /index.php [L]
Is there something additional or something I need to remove/change to what I have to make this work correctly?
15 years 1 month ago #108605 by MisterAegir
Upon investigation, it appears to be something specific to how Network Solutions (web host) handles the apache mod_rewrite. Has anyone had any experience with this? If so, what's the way to resolve this either in the .htaccess file or with editing another file?
15 years 1 month ago #109144 by Matias
Apache error logs could tell you more.
14 years 6 months ago - 14 years 6 months ago #123430 by sozzled
