Question kunena 1.7 get it to work with system mootool off, how?
14 years 7 months ago #107348 by dontorus
Hi, I ask you a question, is there any way to run with system Kunena mootools disabled??
Mootols system is important for Kunena, and if I try to turn it off, Kunena no longer works as it should work, so I wonder if there is a solution to run off with mootools Kunena. Thanks
14 years 7 months ago #107384 by xillibit
Why do you want disable mootools ? Can-you explain what issues you have ?
14 years 7 months ago #107631 by Matias
Kunena NEEDS Mootools upgrade plugin to work. There is no way around it. But if all the modules, plugins and template are fully compatible with latest Joomla versions, Kunena can detect that plugin is not turned on and manually loads it.
Time to create page: 0.230 seconds
