Question Access control problem
15 years 2 months ago - 15 years 2 months ago #106275 by FroboZ
I have just upgraded to kunena 1.7 from 1.5 and I am having some issues with access control, I was using an extension to achieve this in 1.5 where it worked fine, now it dosen't seem to.. I'm hoping I have just misunderstood the Joomla users group system.
So this is my current set up:
I have a usergroup like so
Public - A - B - Registered
And I have my categories and forums configured like so
Cat Forum Access Public public Forum public Registered registered Only A A only Forum A only B B only Forum B only
Now a user that I have assigned to Registered and A still is getting access to B, even if I uncheck Registered and only have A checked in (and even if I uncheck public).
Should I be doing something different or is there a real problem here?
Thanks in advance for your help,
Christopher
Here is my configuration settings
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 20M
Joomla default template details : masqueradekalmar5a | author: Christopher Karlsson | version: 5a | creationdate: 2011-09-05
Kunena default template details : Reddy | author: gonzaunit | version: 1.6.0 | creationdate: 2010-07-04
Last edit: 15 years 2 months ago by FroboZ.
15 years 2 months ago #106320 by Jiminimonka
I am having a similar problem today, trying to make certain parts of my forum accessible to a new user group. So I am watching this space to see a solution.
Please read the FAQ.
Only one question per topic.
15 years 2 months ago #106342 by Jiminimonka
I have been reading all the forum posts on this subject, some going back 2 years, and there is not a single straight answer anywhere. ArtofUser is not updated for Joomla 1.7 so that is out of the question.
I have made a new User Group in Joomla called Members.
I have 3 forum sections. Registered Users can post and read the first forum. Once they get promoted to Member rank, they should be able to read the other forums.
In the Kunena category manager, I have set the first forum access to Registered (and the secondary user one to Registered as well). The other two categories are set to Member.
That should be that, since Kunena user groups are just cosmetic mostly (except the Admin and Moderator roles).
However, users that are in these groups can still see all the boards, or they can see none of the boards, or unexpected results.
So, its either I am doing something wrong, or there is something wrong in Kunena or Joomla.
Here is my config setting:
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 32M | Max file upload: 20M
Joomla default template details : rt_camber | author: RocketTheme, LLC | version: 1.1 | creationdate: August 5, 2011
Third-party components: UddeIm 2.5
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Search 1.7.0
Modules: Kunena Search 1.7.0
15 years 2 months ago #106369 by Matias
Replied by Matias on topic Re: Access control problem
Your settings should work -- just remember that currently admins can see it all.
Also note that Joomla stores group information into session, so you cannot use one user to test those -- or at least you need to log out between tests.
15 years 2 months ago #106370 by Jiminimonka
I have 3 PC's and 3 accounts to test it on. Also phoned up someone and got them to test it. Also I tried logging out, didn't seem to work either.
Just posted an announcement though, for feedback from other users, just in case. I will let you know the outcome.
15 years 2 months ago #106371 by Matias
@Jiminimonka: Instructions written 2 years ago are no good on Joomla 1.7. :)
I need to reproduce this issue locally in order to see if there's something wrong in permission handling. The code itself is very simple and seems to be OK..
Time to create page: 0.170 seconds
