Question Cant get into Forum Configuration
15 years 4 months ago #100752 by vetelmo
Im noticing that this says the The file doesn't exist comprofilej.xml down below. I have it on my system and just got it working a few minutes ago. Anything i need to do?
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 50M | Max file upload: 15M
Joomla default template details : beez_20 | author: Angie Radtke | version: 1.6.0 | creationdate: 25 November 2009
Third-party components: CommunityBuilder: The file doesn't exist comprofilej.xml !
15 years 4 months ago #100753 by sozzled
If you are describing an issue with your K 1.6 configuration report, this is a known problem with the report generator and J! 1.6 because the report generator does not pick up the correct details about certain Joomla extensions. There is nothing that you need to do about Community Builder unless you are not using CB 1.4. What version of CB do you have installed?
The following user(s) said Thank You: vetelmo
15 years 4 months ago #100756 by vetelmo
I am using 1.4
I get this error when I click on the icon for Forum COnfiguration
Fatal error: Cannot redeclare class KDatabaseQuery in /home/content/.../../../administrator/components/com_kunena/libraries/joomla/database/databasequery.php on line 94
15 years 4 months ago #100759 by sozzled
I have not seen this error before. I do not know what is causing this error. It is possible that your K 1.6 installation is defective.
I suggest that you try to uninstall K 1.6.4 and then re-install K 1.6.4 to see if this fixed your problem (see K 1.6 Installation Guide )
15 years 4 months ago #102525 by netician
I am getting the same error after upgrading Kunena to version 1.6.5 when I try to access the component in the admin area.
Fatal Error: Cannot redeclare class KDatabaseQuery in components/com_kunena/libraries/joomla/database/databasequery.php on line 94
The error was detected in the Kunena Component.
15 years 3 months ago #102714 by xillibit
