Kunena 7.0.8 Released
Posting guide:
For a quick response, please give us as much information that helps us to understand the problem.
Please read first What information should I include when I ask for help (including how to post my configuration report)?
This category is for:
  • Kunena 1.7 product-related issues only; and
  • when your Kunena forum does not work.
Do not use this category:
  • to request adding to or removing from the standard features of Kunena;
  • if your question is of a commonly asked "how to" nature;
  • if you are not using the latest stable release of Kunena; or
  • ▪ general Joomla or website adminstration matters
General hints: How To Ask Questions The Smart Way .
Please read the guides posted as sticky topics in this category.
Also refer to the FAQs menu tab above for frequently asked questions.
Note: Support for, and all questions relating to, K 1.7 will cease on 31 August 2012. Our advice is, if you are having problems with K 1.7, to upgrade to K 2.x as soon as practicable,
Question Kunena 1.7.2 problem
14 years 2 months ago #124562 by tester2102
Hallo
I have installed Kunena 1.7.2 with Community Builder on my Forum and now I have this problem:
500 Internal Server Error
Fatal Error was detected!
Please contact the site owner.
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, [email protected] and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
How can I fix this? PHP.ini is 10MB in joomla 2.5
Thanks a lot for your help!
tester2102
14 years 2 months ago #124570 by sozzled
Replied by sozzled on topic Kunena 1.7.2 problem
I suggest that you read HTTP 500 Internal Server Error and that you post your configuration report.
Time to create page: 0.259 seconds
