Kunena 7.0.8 Released
Posting guide:
For a quick response, please give us as much information that helps us to understand the problem.
Please read first What information should I include when I ask for help (including how to post my configuration report)?
This category is for:
  • Kunena 1.7 product-related issues only; and
  • when your Kunena forum does not work.
Do not use this category:
  • to request adding to or removing from the standard features of Kunena;
  • if your question is of a commonly asked "how to" nature;
  • if you are not using the latest stable release of Kunena; or
  • ▪ general Joomla or website adminstration matters
General hints: How To Ask Questions The Smart Way .
Please read the guides posted as sticky topics in this category.
Also refer to the FAQs menu tab above for frequently asked questions.
Note: Support for, and all questions relating to, K 1.7 will cease on 31 August 2012. Our advice is, if you are having problems with K 1.7, to upgrade to K 2.x as soon as practicable,
Question Posting without registering does not work
14 years 2 months ago #124231 by theman
Joomla: Version 1.7.3
Installed version: Kunena 1.7.2 | 2012-01-31 | 5215 [ Omega ]
I have been using this forum previously on a older joomla but decided to upgrade the joomla along with the Kunena to the above versions.
Everything works fine except the option of letting the visitors post in the forum without creating an account does not work.
Allow Guests to Post/Write is put to YES.
What can this be?
Rgds,
TheMan
P.s. if I upgrade my Joomla to 2.5 along with upgrading the Kunena, will it mess with the urls of the posts already in the system?
14 years 2 months ago - 14 years 2 months ago #124239 by sozzled
G'day, theman, and welcome to Kunena.
We ask, when people use the forum for the first time to look at the FAQs page (see the menu above the forum here) and to read the posting guide which helps you to help us to give you faster answers.
theman wrote: If I upgrade my Joomla to 2.5 along with upgrading the Kunena, will it mess with the URLs of the posts already in the system?
I cannot imagine why upgrading Joomla from an older defective version to a version that's new and less defective will affect URL routing. Such matters, of course, depend entirely on how you've set up Joomla and we not nothing about your Joomla configuration in respect of SEO.
theman wrote: Everything works fine except the option of letting the visitors post in the forum without creating an account does not work.
I cannot say how or why this is a problem without more information from you. The posting guide, printed at the top of this page, shows you how to provide us with additional information (see the animated "hand" icon).
Last edit: 14 years 2 months ago by sozzled.
14 years 2 months ago #124242 by theman
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 10M
Joomla default template details : thegreat | author: Rajendra | version: 1.7.0 | creationdate: 2011-11-28
Third-party SEF components: AceSEF: The file doesn't exist acesef.xml !
14 years 2 months ago #124243 by theman
www.desenzanoitaly.com/forum.html
Do you need to get access to the administrator panel?
Rgds,
Theman
14 years 2 months ago #124244 by sozzled
Thank you for that information. There seems to be some other Joomla extension conflicting with Kunena that is stopping people using the New Topic or Reply options. From your configuration report I see that you are trying to use AceSEF and that would be the first thing I would begin to suspect.
I suggest that you try to see if you can post to your forum by disabling and, if necessary, uninstall AceSEF. Unless you really know why you need these third-party SEF products, there is usually no requirement to install them. If the only need you have for a third-party SEF tool is to generate search-engine friendly URLs then you definitely do not need such products (see how to generate SEF URLs without AceSEF by reading the Search Engine Optimisation (SEO) guide in the Wiki).
14 years 2 months ago #124256 by theman
Thank you for your reply!
I installed the site on another server and uninstalled the AceSEF.
No change :(
Any other ideas?
Time to create page: 0.247 seconds
