Kunena 7.0.8 Released
Posting guide:
For a quick response, please give us as much information that helps us to understand the problem.
Please read first What information should I include when I ask for help (including how to post my configuration report)?
This category is for:
  • Kunena 1.7 product-related issues only; and
  • when your Kunena forum does not work.
Do not use this category:
  • to request adding to or removing from the standard features of Kunena;
  • if your question is of a commonly asked "how to" nature;
  • if you are not using the latest stable release of Kunena; or
  • ▪ general Joomla or website adminstration matters
General hints: How To Ask Questions The Smart Way .
Please read the guides posted as sticky topics in this category.
Also refer to the FAQs menu tab above for frequently asked questions.
Note: Support for, and all questions relating to, K 1.7 will cease on 31 August 2012. Our advice is, if you are having problems with K 1.7, to upgrade to K 2.x as soon as practicable,
Question New Avatar Problem with Kunena 1.7.1 and CB 1.7.1
14 years 7 months ago - 14 years 7 months ago #114698 by SGT_FaceLift
Hello. I recently tried to change my avatar on my site and noticed that the behavior was no longer working as it used to. When I upload the picture to use for the avatar it shows as if it has been uploaded and working but no longer appears on the Login module on the sidebar and doesn't show up on the actual posts. The avatar only shows up in small form on the top of the forum when viewing the index.
This used to work perfectly and only occurs when a user goes to change avatars. All the previous avatars that people had still work so the issue is quite puzzling to me.
I will include some screenshots:
Please note in Screenshot one that the "R" icon is the avatar that I uploaded. It is supposed to show up (it used to anyway) on the right side on top of the 'log out' button.
In screenshot 2, please note that the avatar is correct up top but not in the actual post.
This feature used to work perfectly and now without it the forum is an eyesore. Please help me determine what I need to do or what has changed to correct this issue.
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 128M | Max file upload: 32M
Joomla default template details : Response | author: Sulli | version: 1.0 | creationdate: 2009-08-14
Kunena default template details : ArgentRC Dark | author: Gonzaunit | version: 1.6.0 | creationdate: 2010-08-20
Third-party components: CommunityBuilder 1.7.1 | UddeIm
Modules: Kunena Latest 1.6.4
Last edit: 14 years 7 months ago by SGT_FaceLift. Reason: Fix Config Report..
14 years 7 months ago #114728 by sozzled
I don't think we can help until we see your unedited Kunena configuration report. Please read What information should I include when I ask for help (including how to post my configuration report)? .
Your problem could be caused by any number of things. Could be folder/file permissions; could be a Javascript library conflict with Joomla; could be a Community Builder matter. I don't know. Hard to advise further without the required information )that you've removed) from your configuration report.
Most likely, the issue is caused by using an old, outdated and unsupported Kunena template. What happens if you use the Blue Eagle template?
14 years 7 months ago - 14 years 7 months ago #114763 by SGT_FaceLift
I apologize for that oversight. I edited the original post with the required information.
I will attempt the template change and post back the results. Thank you for your time.
EDIT: Same problem. Screenshot posted:
I wanted to mention that the "Login" box on the right used to display the avatar before this problem appeared. That is the "CBLogin" module and it seems to have the same problem that the avatar function is having within Kunena as well.
Do you advise that I take this matter to the CB Forums? I have searched there for something related to this but I didn't know exactly which website to start on.
Thanks.
14 years 7 months ago #114764 by sozzled
14 years 7 months ago #114766 by SGT_FaceLift
Ah ok, so get Joomla to 1.5.25 and then ditch Legacy mode?
I'll see what I can do.
14 years 7 months ago #114767 by sozzled
Ditch legacy mode, first. That's a must. Chances are that you're using an old J! 1.0 extension that's causing your problem (possibly something to do with CB, I can't say). Update J! 1.5.25 any time. There are a number of security vulnerabilities that are fixed with the later version of Joomla.
The following user(s) said Thank You: SGT_FaceLift
Time to create page: 0.368 seconds
