Posting guide:
For a quick response, please give us as much information that helps us to understand the problem.
Please read first What information should I include when I ask for help (including how to post my configuration report)?
This category is for:
  • Kunena 1.7 product-related issues only; and
  • when your Kunena forum does not work.
Do not use this category:
  • to request adding to or removing from the standard features of Kunena;
  • if your question is of a commonly asked "how to" nature;
  • if you are not using the latest stable release of Kunena; or
  • ▪ general Joomla or website adminstration matters
General hints: How To Ask Questions The Smart Way .
Please read the guides posted as sticky topics in this category.
Also refer to the FAQs menu tab above for frequently asked questions.
Note: Support for, and all questions relating to, K 1.7 will cease on 31 August 2012. Our advice is, if you are having problems with K 1.7, to upgrade to K 2.x as soon as practicable,
Important Wrong link to forum when using multilanguage
15 years 3 months ago #104402 by alliance2000
Hi all!
I'm using a Joomla 1.7 website with multilanguage support (german/english), JomSocial 2.2.4 and Kunena 1.6.5. In the JomSocial-menu there is a button called "forum", which gives in the german version the following link when clicked:
.../index.php/de/forum/aktuell?language=de-DE
The forum opens and everything is fine. When I switch to english, the link is the following:
.../index.php/en/forum/aktuell?language=en-GB
Now the problem is, that the forum-menu is missing! The link calls the wrong module ("forum/aktuell" instead of "forum-en/aktuell-en"). When I change the link manually to the following:
.../index.php/en/forum-en/aktuell-en?language=en-GB
or when I click the "english flag" (in the Joomla language switcher module) the link changes like this:
Tadaa! The menu is visible again. So how can I change the link behavior of the forum-button to the correct behavior?
Thanks for your help!
Jack
Additional info:
As described in the Joomla 1.7 multilange-tutorials I have created 2 Kunena-Menus (1 german only called "kunenamenu" and 1 english only called "kunenamenu-en") and the corresponding menu items are linked between those two menus.
Here is the configuration info from Kunena:
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 128M
Joomla default template details : venor | author: www.venor.net | version: 1.6 | creationdate: 11/04/13
Third-party components: Jomsocial 2.2.4
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Search 1.6.4 | Kunena Discuss 1.6.4 | My Kunena Forum Posts 1.6.4 | Kunena Groups 1.6.4
Modules: Kunena Latest 1.6.4 | Kunena Stats 1.6.4 | Kunena Login 1.6.4 | Kunena Search 1.6.4
15 years 3 months ago #104512 by Matias
We haven't tested Kunena 1.6 in multi-language environment (J1.6+) and it looks like that we forgot to implement the feature.
I will try to fix this into the next release (out in about a week).
15 years 3 months ago #104532 by alliance2000
I have done another approach to the problem and I was able to fix it. I hacked the joomla menu-behavior and implemented a JText-feature. So now I have only one Kunena-menu and it uses JText from the language-ini-files. By doing this, I can use as many languages as I like and need only one Kunena-menu!
Case closed! ;)
Jack
15 years 3 months ago #104651 by Matias
Actually I added some support for this into K1.7.0 -- it's not perfect but works by adding menus for all languages into the same Kunena Menu.
Oh boy -- I hope that I will never need to create a multilingual site in Joomla 1.7! It took me a few hours to figure out how to make it to work, even without Kunena.
14 years 8 months ago #120202 by jschmi
I'm using Kuena on my multi-lingual (German/English) Joomla2.5 site. Though Kuena supports multiple languages the tabs on header do not switch language. So I've set up one set of menus for german language and one set for english language - this works fine but result is that with this configuration now the tabs on header are not displayed anymore. Did I miss anything by doing so? Or is this not supported at all (I'm running Kuena 1.7.2)?
greeting,
Jochen
14 years 8 months ago #120217 by sozzled
Time to create page: 0.146 seconds
