This category is only for reporting defects or problems with Kunena 1.6 test versions with Joomla 1.6. This is NOT a support forum - there is no support for test versions. Users should NOT install K 1.6 alpha or beta test versions on websites with live production data.
Question Loaded 1.6.3 on a J1.6.1 by mistake :/ Help needed (Blank Page)
15 years 5 months ago - 15 years 5 months ago #92365 by mata230
By mistake I installed Kuneta 1.6.3 extension on my Joomla 1.6.1 but after installing the module I didn't continue after the "Installing component was successful." "Select an Installation or Upgrade Option" as I was reading the forums at the same time and advised against it. When I bring up my main site it's a blank screen, I tried removing all the kuneta components but I'm stuck with these 2 components:
Kunena Forum - English Administrator Published Language 1.6.3 2011-01-31 Kunena Team N/A 601
Kunena Forum - English Site Published Language 1.6.3 2011-01-31 Kunena Team
When I try to remove them I get the following message:
* This language can't be uninstalled as long as it is defined as a default language.
Any help would be greatly appreciated as my site is now down :/ as when loading the main site it goes to a blank page, only the administration panel is accessible.
Michael
Last edit: 15 years 5 months ago by mata230.
15 years 5 months ago #92404 by 810
1) Install K1.6.3 again
2) Uninstall kunena
Then the languages are deleted.
if not. Go to your ftp. to \language\en-GB delete all kunena files. and go to \administrator\language\en-GB delete also the kunena files.
regards
810
Time to create page: 0.247 seconds
