This category is only for reporting defects or problems with Kunena 1.6 test versions with Joomla 1.6. This is NOT a support forum - there is no support for test versions. Users should NOT install K 1.6 alpha or beta test versions on websites with live production data.
Question Some Problems to solve!
15 years 5 months ago #91587 by Carthondor
Legacy mode: Disabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Disabled | FTP layer: Enabled |
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 65M | Max file upload: 200M
Joomla default template details : dark-alliance_j1.6 | author: Carthondor | version: 1.6.0 | creationdate: 1/26/2011
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 2.2.0) | UddeIm: Disabled or not installed
Hello KunenaTeam,
with my Database Clone to Test and make my Homepage for Joomla 1.6.1 ready, i got some Problems with Kunena.
1. Profilpage leaves blank
2. Create New Topic leaves blank
3. No BB Codes can be seen (I cant find the Mootools Plugin for Joomla 1.6)
I have read some Topics here, but i have not found any Help to solve my Problems.
I Have no Problem to wait till Kunena 1.6.4 HotFix is done, when you say, that my Problems will fixes with this 1.6.4 Patch. If not, please help me to get Kunena 1.6.3 run, on my Homepage.
Thy for Help. Greetz Carthondor
15 years 5 months ago #91599 by xillibit
1 & 2 : Set error reporting on maximum in Joomla! configuration panel
3 : Joomla 1.6 has no mootools plugin, you could have a conflict with an another javascirpt library
15 years 5 months ago - 15 years 5 months ago #91602 by Carthondor
I got right, i had some Problems with coded Javascript. Now it´s fixed and Kunena is running well!
Last edit: 15 years 5 months ago by Carthondor.
Time to create page: 0.217 seconds
