This category is only for reporting defects or problems with Kunena 1.6 test versions with Joomla 1.6. This is NOT a support forum - there is no support for test versions. Users should NOT install K 1.6 alpha or beta test versions on websites with live production data.
Question J! 1.6 and K 1.6 problems for beginners
15 years 5 months ago - 15 years 5 months ago #91099 by jazzzbo
I've just started using K2unena, and have a couple of problems I can't seem to fix...
1. I'd like to get rid of the 'Welcome to Kunena' topic under Recent Topics. I believe I am set up as admninistrator, but can't find a way to delete it.
2. The tab color is light blue on a dark blue or charcoal. ( www.calgarybridge.org/index.php/forum ) What file do I need to edit to fix this? Where do I find it?
My Configuration
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 10M
Joomla default template details : beez_20 | author: Angie Radtke | version: 1.6.0 | creationdate: 25 November 2009
Jim
Last edit: 15 years 5 months ago by sozzled. Reason: Changed subject to improve relevance for search purposes
15 years 5 months ago - 15 years 5 months ago #91101 by sozzled
(1) The Welcome to Kunena topic is easily removed. You delete the topic just like you would delete any other topic. You do this from the frontend; you have to be logged in as a site administrator or forum moderator to delete topics.
(2) Please read K 1.6 Technical Requirements . You need to understand that K 1.6.3 is not 100% compatible with J! 1.6. This issue has been fixed in K 1.6.4 (which is not yet available for public release at this time) so you need to wait for this new release or search the forum to see how to workaround your problem. We do not recommend J! 1.6.0 for anything - this version of Joomla is not very reliable. If you must use Joomla 1.6, please upgrade to J! 1.6.1 but, even so, there will be difficulties using J! 1.6.1 and K 1.6.3, too.
At this time we do not recommend J! 1.6 as a base platform for beginner users of Kunena and Joomla unless they are aware of many technical difficulties that are involved. J! 1.6 is not without its own teething problems.
The following user(s) said Thank You: Delphi32
15 years 5 months ago #91122 by jazzzbo
Thanks for your observations and advice.
Is upgrading Joomla just a matter of installing the new version over the old, or do I need to start all over again as I did on the 1.5 to 1.6 upgrade?
J
15 years 5 months ago #91123 by sozzled
You should ask questions about how to upgrade J! 1.6.0 -> J! 1.6.1 on the Joomla forum.
Time to create page: 0.260 seconds
