Kunena 7.0.2 Released
The Kunena team has announce the arrival of Kunena 7.0.2 [K 7.0.2] in stable which is now available for download as a native Joomla extension for J! 5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Important Problem with menu and forum display
"I also realised that I don't have any Categories in the menu."
Do you mean you have nothing published in the "Kunena Menu"? So when you go to your Joomla back end go to under Menu. You should have one called "Kunena Menu" by default. Click the Kunena Menu.
Whats published there?
thetoast wrote: Do you mean you have nothing published in the "Kunena Menu"? So when you go to your Joomla back end go to under Menu. You should have one called "Kunena Menu" by default. Click the Kunena Menu.
Sorry for the misunderstood, I mean that I don't see the Categories in the menu of kunena. The kunena menu is published and we can see it, like in the screeenshoot. Just in a weird way, like the rest of the forum.
You can have a direct link to my forum via this :
thinkhead.homeserver.com:81/xerossysteme/index.php/forum
That's one of your problems. See Sections, Categories, sub-Categories (Part 1) . You need at least one section and one category in that section. When you install Kunena, the installation creates one section and two categories. You've deleted them and that is why you have the message "Il n'y a pas de forum dans cette catégorie !"
The other problem that you have is that your menu links are laid out in a vertical pattern instead being in a horizontal arrangement like here. That's a problem with your site template. See [Merged topic] Menu tabs display vertically
In your case, I would recommend uninstalling Kunena, drop all database tables jos_kunena_* and start again. If you've not used Kunena before, even if you don't like the way that it looks when it's first installed, resist the temptation to change things until you make sure that everything works properly.
Do I reinstalled anyways ?JInstaller: :Install: Cannot find XML setup file
Could not delete the administrator menus.
Component Uninstall: Can't uninstall. Please remove manually
The install Kunena again. Let us know if you have any problems installing Kunena again.
