This category is only for reporting defects or problems with Kunena 1.6 test versions with Joomla 1.6. This is NOT a support forum - there is no support for test versions. Users should NOT install K 1.6 alpha or beta test versions on websites with live production data.
Question "Mark all topics read" does not work
15 years 7 months ago #90826 by Kyristan
Hello again :)
I just finished a new installation of Kunena 1.6 and Joomla 1.6.1.
Both, Joomla and Kunena use the german speech files.
I now have the problem, that I cannot use the "Mark all topic read"-Button.
When I use this Button I get the following error:
500 - Kunena function "category" not found on the standart Joomla Error-Page.
I also activated the debug-mode, but it just says the same.
This is my configuration:
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 24M | Max file upload: 8M
Joomla default template details : butterflyfairyfree | author: Alexander Hilliger | version: 1.0.0 | creationdate: 17 January 2011
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Disabled or not installed | UddeIm: The file doesn't exist uddeim.j15.xml !
Thanks for looking :cheer:
15 years 7 months ago #90828 by Kyristan
Ok, I just solved the Problem:
It happens when I activate "search engine friendly urls" (I hope its called like that in english) in the Joomla-Backend.
Now its disabled and everything seems to work.
I will do some more tests, and give you an update if I shouls encounter that error again.
15 years 7 months ago #90871 by sozzled
You did not have SEO configured properly in the first place. Please read Search Engine Optimisation (SEO) in the Wiki to find out how to properly setup SEO. Everything should work after that.
Kunena works great in with standard Joomla SEO (even if K 1.6.3 is not 100% suitable for J! 1.6.1 yet and J! 1.6.1 is not, in the opinion of many people, totally reliable for building new websites with, either).
15 years 7 months ago - 15 years 7 months ago #91643 by wolfhound512
A similar problem.
When I'm on the index forum page ( albalynx.local/forum ) - the form action url of "Mark all topics read" button is " albalynx.local/index.php?option=com_kunena "
When I click on the button, I was redirected to " albalynx.local/component/kunena/listcat?Itemid=0 "
And then the form action url is look like " albalynx.local/component/kunena/index.php?option=com_kunena "
When you click on that an error occurs "500 - Kunena function "index.php" not found"
SEO settings:
Search Engine Friendly URLs: Yes
Use Apache mod_rewrite: Yes
Add suffix to URLs: No.
All other links and forms work fine.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 16M
Joomla default template details : rt_maelstrom_j16 | author: RocketTheme, LLC | version: 1.6.0 | creationdate: March 18, 2011
Last edit: 15 years 7 months ago by wolfhound512.
15 years 7 months ago #91645 by xillibit
Please wait k1.6.4 release which will fix the issue
The following user(s) said Thank You: Rx Ricardo, wolfhound512
15 years 7 months ago #91717 by steenmf
Hi.
Still another one with similar problem:
When I click on the Forum link in my Main Menu the url shows:
.../index.php?option=com_kunena&view=entrypage&defaultmenu=335&Itemid=732
- and the Forum shows up with the right Item Id (732), but when I click on any Category or Topic in the Forum the url gets like this:
... www.neury.com/index.php?option=com_kunen...at&catid=31&Itemid=0
- that is: all Categories and Topics get ItemId=0 at the end of the url, which messes up my site appearence.
Is this a bug that will be fixed with the K1.6.4 release, or is there anything to be done now to fix this?
Best regards B)
Config. report:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 48M | Max file upload: 32M
Joomla default template details : ja_ores | author: JoomlArt.com | version: 1.1.6 | creationdate: 09/15/2010
Kunena default template details : Example Template | author: Kunena Team | version: 1.6.3 | creationdate: 2011-01-31
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.4) | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 1.5)
Time to create page: 0.208 seconds
