This category is only for reporting defects or problems with Kunena 1.6 test versions with Joomla 1.6. This is NOT a support forum - there is no support for test versions. Users should NOT install K 1.6 alpha or beta test versions on websites with live production data.
Question Forum content highlighted on home button instead of forum
15 years 2 months ago - 15 years 2 months ago #90432 by kozzmic
My sites has 2 menus
forum menu kunena
Normal menu with 1 button called forum wich directs to forum but
When i click a topic, the home button is highlighted instead of the forum button, wich makes it impossible to assign modules properly and stuff
anyone knows a fix? J1.6.1 and kunena 1.6.3
Last edit: 15 years 2 months ago by kozzmic.
15 years 2 months ago - 15 years 2 months ago #90939 by GoremanX
a) make sure your Kunena menu has "kunenamenu" as its unique name
b) make sure this menu contains at least one item with the alias "forum" (mine is a Menu Link that links to a different "Forum" entry in the Main Menu)
c) Create your menu structure in the Main Menu. Make sure the item you want to use as the "Forum" item is an "Entry Page" type.
a) and b) must exist in some form (an item called "forum" in a menu called "kunenamenu"). If they don't, you'll always get the problem you're describing.
By the way, Kunena 1.6.3 does not yet support Joomla 1.6 very well. You're better off waiting for Kunena 1.6.4, which is due out very soon.
www.friendlyphotozone.com
Last edit: 15 years 2 months ago by GoremanX.
Time to create page: 0.204 seconds
