Kunena 7.0.2 Released
The Kunena team has announce the arrival of Kunena 7.0.2 [K 7.0.2] in stable which is now available for download as a native Joomla extension for J! 5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
This category is only for reporting defects or problems with Kunena 1.6 test versions with Joomla 1.6. This is NOT a support forum - there is no support for test versions. Users should NOT install K 1.6 alpha or beta test versions on websites with live production data.
Question Kunena 1.6.3 Problems with CSS
15 years 3 weeks ago #86776 by men1079
Hello, after the default installation I have a problem with Kunena menu. It seems that CSS tables do not implement the module kunema_menu. See attached screenshot:
How can I resolve this problem? Thank you
15 years 3 weeks ago #86798 by GoremanX
What Joomla template are you using? There might be a conflict between your Joomla template and Kunena.
www.friendlyphotozone.com
15 years 3 weeks ago - 15 years 3 weeks ago #86807 by men1079
I'm using joomla default template "Beez2 - Default". And i tried to use others joomla templates (for example, "YT Enterprise" from YooTheme), but i have same result.
My test site
Last edit: 15 years 3 weeks ago by men1079.
15 years 3 weeks ago #86854 by sozzled
This is a Joomla 1.6 website.
Yes, we are aware of these issues. They will be resolved in an upcoming release of Kunena. Thank you for your report.
The following user(s) said Thank You: men1079
15 years 3 weeks ago #86857 by men1079
Thank you for your reply.
Please tell me when Kunena plans to release this update, thanks.
15 years 3 weeks ago #86860 by sozzled
I don't know the exact date of the release and I don't know to what extent the next release (K 1.6.4) will address this situation, either.
If you use J! 1.6 you will encounter problems. If you need to have a website built, running and working quickly, we recommend J! 1.5.22. If you are not in any hurry then you can experiment with J! 1.6.
Time to create page: 0.285 seconds
