This category is only for reporting defects or problems with Kunena 1.6 test versions with Joomla 1.6. This is NOT a support forum - there is no support for test versions. Users should NOT install K 1.6 alpha or beta test versions on websites with live production data.
Question Profiles not saving?
15 years 9 months ago #85224 by RickA
Profiles not saving? was created by RickA
I am running the latest official release of Joomla and the latest official release of Kunena and I am having a issue where if I try and change any profile settings they are not reflected after I hit save including avatars. I get no errors ... its just the avatar does not show nor does any any information I enter and save in the profile stick.
What could I be doing wrong?
15 years 9 months ago - 15 years 9 months ago #85226 by sozzled
Replied by sozzled on topic Re: Profiles not saving?
G'day, RickA, and welcome to Kunena.
Can I please confirm my understanding of what you have written.
Joomla 1.5.22 and Kunena 1.6.3. Is that correct?
Last edit: 15 years 9 months ago by sozzled.
15 years 9 months ago - 15 years 9 months ago #85229 by RickA
Replied by RickA on topic Re: Profiles not saving?
Joomla 1.6 and Kunena 1.6.3
I guess I should also clarify ... when I say settings not sticking I am speaking specifically as a user not in the admin section. What I save in the admin section as configuration saves and shows as changed. It is information in profile like location, sex, address, avatar etc when updated does not show after being saved.
Last edit: 15 years 9 months ago by RickA.
15 years 9 months ago #85303 by xillibit
Replied by xillibit on topic Re: Profiles not saving?
I have just found what is going wrong, the entry for the user in kunena_user isn't created, so you need sync users in Kunena backend.
15 years 9 months ago #85316 by singletrack
This has been reported here , and here .
The only work around is to sync manually - which is not ideal by any stretch.
15 years 9 months ago #85802 by RickA
I can only imagine this "bug" is being worked on and a fix will be released shortly? Here is hoping. Other than that issue I am impressed so far with the forum. Good work Kunena team!
