This category is only for reporting defects or problems with Kunena 1.6 test versions with Joomla 1.6. This is NOT a support forum - there is no support for test versions. Users should NOT install K 1.6 alpha or beta test versions on websites with live production data.
Question Troubles using K1.6 on J1.6
15 years 9 months ago #84812 by Zero9195
sometimes it works some times not
15 years 9 months ago #84813 by Zero9195
15 years 9 months ago #84814 by Zero9195
I can't edit my posts, and I can't post alrger than this posts here. Could I pm my Report to you?
15 years 9 months ago #84860 by sozzled
Please run the K 1.6 report feature, then copy the BBcode and paste it here as a normal post. That's all that you need to do.
15 years 9 months ago - 15 years 9 months ago #84885 by Zero9195
I know, I have troubles with my Computer. I can't edit pposts in this and other Forums, and can't write large messages. I will post it here, when it works again. Sorry for the trooubles I cause you here.
Last edit: 15 years 9 months ago by Zero9195.
15 years 9 months ago #85045 by Zero9195
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 16M | Max file upload: 2M
Joomla default template details : beez_20 | author: Angie Radtke | version: 1.6.0 | creationdate: 25 November 2009
Finally, here it is. I'm sorry for the spamming here, but I had troubles with my Computer because of Windows, but now everythin gworks fine ;)
Thanks for helping!
