This category is only for reporting defects or problems with Kunena 1.6 test versions with Joomla 1.6. This is NOT a support forum - there is no support for test versions. Users should NOT install K 1.6 alpha or beta test versions on websites with live production data.
Question Sync Problem
15 years 9 months ago #84151 by GrdPa
Sync Problem was created by GrdPa
Hello.
First, I apologize for my English disastrous, I'm French.
I just installed Kunena 1.6.3 on my site in joomla 1.6 and I have a trouble when registering new users. Indeed, they are not automatically created under Kunena which forces me to manually sync so they can edit their avatar and profile.
Thank you in advance for your help.
Joomla default template details : ja_teline_iv | author: JoomlArt.com | version: 1.0.1 Beta | creationdate: 25 Jan 2011
Modules: Kunena Latest: Enabled (Version : 1.6.2) | Kunena Stats: Disabled or not installed | Kunena Login: Enabled (Version : 1.6.2)
15 years 9 months ago #84599 by singletrack
Replied by singletrack on topic Re: Sync Problem
I am also having this issue, with no resolution to be found.
Only way to get Kunena User profiles created from Joomla! 1.6 have been to manually sync. By that time the new users have left without updating any of their information. I have had to place a message on the front page that it is a known issue that I am working to resolve.
15 years 9 months ago #84654 by singletrack
This is my config report:
Joomla default template details : siteground-j16-1 | author: SiteGround | version: 1.0.0 | creationdate: 11 January 2011
Kunena default template details : Euro-BBlue | author: Mizunga | version: 1.6.1 | creationdate: 2010-12-20
Time to create page: 0.147 seconds
