This category is only for reporting defects or problems with Kunena 1.6 test versions with Joomla 1.6. This is NOT a support forum - there is no support for test versions. Users should NOT install K 1.6 alpha or beta test versions on websites with live production data.
Question Public access level
15 years 9 months ago - 15 years 9 months ago #83529 by leech13a
Public access level was created by leech13a
I'm totaly new to Joomla/Kunena, thus maybe I am missing something.
I have installed new Joomla 1.6 + Kunena 1.6.3 (from 31 Jan) and went to forum management straight away.
At first I saw two forums + 1 section from sample data with Public Access Level set to "Everyone". I deleted those and created new ones.
However, those new forums have public access as "nobody". I went into settings and there is "public selected". I don't see any group as "Everyone" or "Nobody".
Is that correct or some bug? How to make forum readable for everyone?
In _kunena_categories table there is accesstype='none', access=1 and pub_access=1 and for all items in table
UPDATE:
I played in SQL with that table - seems that "everyone" group is visible when pub_access=0.
I don't know where to set that from GUI, but I guess the "Everyone" group is missing from some php file.
Last edit: 15 years 9 months ago by leech13a.
15 years 9 months ago #83733 by marco168
Replied by marco168 on topic Re: Public access level
also found that any new category will set access level to "nobody" default. How could we change the default value~
15 years 9 months ago #84340 by reemet16
Replied by reemet16 on topic Re: Public access level
I have also same problem :(
15 years 9 months ago #84343 by GrdPa
Replied by GrdPa on topic Re: Public access level
nobody = everyone
It's the same access.
15 years 9 months ago #84346 by marco168
But i cannot found the category in frontend, unless i change it to everyone...
15 years 9 months ago - 15 years 9 months ago #84349 by reemet16
i found a solution.
At first put the access level to registered. Save it.
Then change it to public.
In backend it shows still nobody but its now available on frontend
Last edit: 15 years 9 months ago by reemet16.
