This category is only for reporting defects or problems with Kunena 1.6 test versions with Joomla 1.6. This is NOT a support forum - there is no support for test versions. Users should NOT install K 1.6 alpha or beta test versions on websites with live production data.
Question J! 1.6 & K 1.6.2 - Fatal error: Class 'JParameter' not found
15 years 10 months ago #81761 by bagou01
hi
when on joomla 1.6.0, i create a menu button to a kunena profile, i get this message when i click on the button:
Fatal error: Class 'JParameter' not found in /home2/alabelge/public_html/components/com_kunena/kunena.php on line 210
15 years 10 months ago #81766 by xillibit
Replied by xillibit on topic Re: new bug in K1.6.2
This is an known issue under Joomla! 1.6, it will be fixed under K1.6.3
15 years 10 months ago #81767 by bagou01
Replied by bagou01 on topic Re: new bug in K1.6.2
k nice then :)
15 years 9 months ago #84846 by tforsman
using 1.6.3 and still an issue for me :unsure:
Fatal error: Class 'JParameter' not found in /components/com_kunena/kunena.php on line 210
Installed version: Kunena 1.6.3 | 2011-01-31 | 4344 [ Parlare ] | Copyright: © 2008-2011 Kunena | License: GNU GPL
15 years 9 months ago #84903 by xillibit
I think this one has been forgot, thanks for remimder, i will add this in bug tracker
15 years 9 months ago #84939 by satikas
While peeps work on the 1.6.4, you can fix the error by adding
jimport( 'joomla.html.parameter' );
to the problematic files beginning, in this case kunena.php
The following user(s) said Thank You: singletrack, disismi
