- Thank you received: 10
Kunena 6.2.6 released
Question Full Screen Pictures Problem in 1.6.2
After the upgrade thumbnail pictures shows but when I click on the thumbnail / image link the full screen is just white
here is the a sample:
www.cyberg.ir/index.php?option=com_kunen...&id=61655&Itemid=118
Legacy mode: Disabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
This message contains confidential informationhtaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 24M | Max file upload: 100M
Joomla default template details : rt_zephyr_j15 | author: RocketTheme, LLC | version: 1.5.1 | creationdate: August 9, 2010
Kunena default template details : Blue Eagle (default) | author: Kunena Team | version: 1.6.2 | creationdate: 2010-12-29
Kunena version detailled: Installed version: 1.6.2 | Build: 3894 | Version name: Team | Kunena detailled configuration:
board_title Cyberg board_offline 0 board_ofset 0 offline_message <h2>The Forum is currently offline for maintenance.</h2>
Check back soon!enablerss 1 enablepdf 1 threads_per_page 20 messages_per_page 10 messages_per_page_search 20 showhistory 1 historylimit 10 shownew 1 jmambot 0 disemoticons 0 template default showannouncement 1 avataroncat 1 catimagepath category_images/ showchildcaticon 1 annmodid 62,63 rtewidth 500 rteheight 400 enableforumjump 1 reportmsg 1 username 1 askemail 1 showemail 0 showuserstats 1 showkarma 1 useredit 1 useredittime 0 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 0 allowfavorites 1 maxsubject 50 maxsig 300 regonly 0 changename 1 pubwrite 0 floodprotection 25 mailmod 0 mailadmin 0 captcha 0 mailfull 1 allowavatar 1 allowavatarupload 1 allowavatargallery 1 avatarquality 90 avatarsize 120 allowimageupload 0 allowimageregupload 1 imageheight 1600 imagewidth 1600 imagesize 5000 allowfileupload 0 allowfileregupload 1 filetypes zip,txt,doc,gz,tgz,w3g,rar,pps,zip filesize 5000 showranking 1 rankimages 1 avatar_src fb_profile pm_component userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 1 userlist_username 1 userlist_posts 1 userlist_karma 1 userlist_email 0 userlist_usertype 0 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 1 latestcategory 0 showstats 1 showwhoisonline 1 showgenstats 1 showpopuserstats 1 popusercount 15 showpopsubjectstats 1 popsubjectcount 15 usernamechange 0 rules_infb 1 rules_cid 267 help_infb 0 help_cid 1 showspoilertag 1 showvideotag 1 showebaytag 1 trimlongurls 1 trimlongurlsfront 200 trimlongurlsback 200 autoembedyoutube 1 autoembedebay 1 ebaylanguagecode en-us fbsessiontimeout 1800 highlightcode 1 rss_type post rss_timelimit month rss_limit 15 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 100 rss_old_titles 1 rss_cache 900 fbdefaultpage categories default_sort asc alphauserpointsnumchars 10 sef 0 sefcats 0 sefutf8 1 showimgforguest 1 showfileforguest 1 pollnboptions 10 pollallowvoteone 1 pollenabled 1 poppollscount 5 showpoppollstats 1 polltimebtvotes 00:15:00 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 50 ordering_system mesid post_dateformat ago post_dateformat_hover datetime hide_ip 0 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 50 thumbheight 100 thumbwidth 100 hideuserprofileinfo put_empty integration_access joomla integration_login joomla integration_avatar kunena integration_profile kunena integration_private uddeim integration_activity alphauserpoints boxghostmessage 0 userdeletetmessage 1 latestcategory_in 1 topicicons 1 onlineusers 1 debug 0 catsautosubscribed 0 showbannedreason 1 version_check 1 showthankyou 1 showpopthankyoustats 1 popthankscount 5 mod_see_deleted 0 bbcode_img_secure text listcat_show_moderators 1 lightbox 1 activity_limit 0 show_list_time 720 show_session_type 0 show_session_starttime 0 userlist_allowed 0
Third-party components: AlphaUserPoints: Installed (Version : 1.5.12) | CommunityBuilder: Disabled or not installed | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.1)
Modules: Kunena Latest: Enabled (Version : 1.6.0-RC2) | Kunena Stats: Enabled (Version : 1.6.0-RC2) | Kunena Login: Enabled (Version : 1.6.0-RC2)
i think its a conflict with the footer, can you disable that in the Rockettheme template. and try again.
810 wrote: hello,
Thank you for your reply
I've disable the footer but nothing happen.
Please be mention that when I inspect the image box in view mode via Firebug I can not see any image url in generated code.
Thank you for pursuing, and please be mentioned I've had this problem after upgrading to .6.2 version
regards 810
Moreover the com_kunena component is in exclude list of JCH.
Disable jcemediabox in Plugins
810 wrote: Next try.
Next Advice pls the JCE Media Box is disable now
Kunena uses 2. One of them is Mootools 1.2.4; the other one is for the lightbox effect.
So, all you have to do is find out which one of the other 12 Javascript libraries is interfering with the Kunena lightbox display and you've solved your problem. Basically, this means that you need to uninstall all the other plugins, modules, templates one by one until you manage to get the lightbox effect working. Then you can re-install those things you've uninistalled except for the one that's caused the problem in the first place.
