Question Users cannot edit their own profiles
15 years 4 months ago - 15 years 4 months ago #99829 by Topuk
For some reason my users can not edit their own profiles... can you help me?
Joomla 1.5.23
Kunena 1.6.4
www.dps.rrbe.net
Joomla default template details : v1_200005 | author: iGuildTemplates | version: 1.0 | creationdate: 2010-04-05
Last edit: 15 years 4 months ago by sozzled. Reason: minor edit/spelling in subject
15 years 4 months ago - 15 years 4 months ago #99832 by sozzled
G'day, Topuk, and welcome to Kunena.
The amount of space that you have allocated to Kunena - the overall width of your forum - is very limited and may be a factor in your problem. Try removing the right-hand modules from your site to see if it makes a difference.
When you wrote "for some reason ..." it would help to know a little more about what is going on at your website. I suspect it's a Javascript conflict issue ... but that's a wild guess. Please read the FAQs about Kunena (see the tab at the top of this page); I think that will help.
15 years 4 months ago - 15 years 4 months ago #99834 by Topuk
The problem that I am having is that when members select edit for their profile, most of the options (ie. facebook, googletalk etc) are not editable.
I have checked the Mootools and it is version 1.25
Last edit: 15 years 4 months ago by Topuk.
15 years 4 months ago - 15 years 4 months ago #99835 by sozzled
Thank you for your reply.
I haven't seen this problem before. This is very strange. :S I'm beginning to wonder of the problem is not caused by a corrupted installation of Kunena or maybe some configuration parameter?
First suggestion: reset your Kunena configuration to default values
Second suggestion: go to Integration tab and specifically set all options to the values that are appropriate to your circumstances (most of them will be "Joomla" or "None")
Third suggestion: Re-inistall K 1.6.4 (see K 1.6 Upgrade Guide ) - you will not lose any configuration details or data.
15 years 4 months ago #99836 by Topuk
I ran through all 3 options and still no dice :(
15 years 4 months ago #99837 by Silhouette.NSW
Topuk wrote: I ran through all 3 options and still no dice :(
Ditto for me, installed the new version yesterday, added myself, edited it etc. Today cannot edit my profile.
regards
David
Time to create page: 0.154 seconds
