Question NO Photo upload
Kunena Search, Stats and Latest software are add-ons and they are installed separately.
It's in your interests to do something about "legacy mode", now, before problems occur later and you find yourself stuck.
In connection with uddeIM, I would never use a "release candidate" version of software on my live, production website.
I don't have anything specific to add about your inability to upload photos, except to ask you what size (in Kb) images you are trying to upload and whether you are getting any messages to indicate why the feature does not work.
The photo sizes were 500x500 and under 40kb, they are basically the same as the others, and how are up and working fine
The only error message I was getting was in EDIT= =Warning: Invalid argument supplied for foreach() in components/com_kunena/lib/kunena.parser.php on line 571 and Today it is working
As for uddeIM iI have 2.3/stable on the test site and uddeIM 2.0rc/2009-12-24/dev on my live site because at the time I uploaded the WRONG one, as I only started to learn about Joomla 18 months ago
I am on my test site and turning ON-OFF the System - Legacy plugin but just getting a 'Direct Access to this location is not allowed' on my front page, so I will be searching the forums to find out why
I will get everything updated ASAP thanks
'Direct Access to this location is not allowed' means that you have a J! 1.0 component/plugin/module/template that requires Joomla 1.0 or J! 1.5 with the System - Legacy plugin enabled. As you would be aware, Joomla support for J! 1.0 was withdrawn on 22 July 2009. Therefore, any continued use of such software after that time is done at indivudual users' own risk and without any support from the Joomla community-at-large.
It is against this background and in this context, that users are encouraged to adopt best practice in maintaining their websites to assure themselves that they have done everything they can to prevent the likelihood of problems catching them when they least expect it. It is for this reason that users should be concerned about how they're using Joomla (even if the "legacy mode" feature still exists in the ongoing new releases of J! 1.5.x) in order to invest in the general well-being of their sites. It is for these reasons that we should take steps to reduce the possibility of problems arising and to have confidence that things will work for a long time to come; removing one's dependence on legacy mode is one step in the right direction. I don't think there's any disagreement in the arguments that I have put forward in achieving those objectives.
There were no guarantees that legacy mode would always work and there are no guarantees that legacy mode will continue to work in they way that people may expect it to continue to work. With each successive release of Joomla pushing further from the software solutions of the past, there is no better time than now to focus on why legacy software ought to exist as a viable strategic solution to the problems that confront web developers today. Let me put it another way: legacy software may have had some tactical advantages in the past, when other alternatives were unavailable; that tactical advantage does not exist today with the availability of better choices, reliable choices and more resilient strategic alternatives.
To identify which J! 1.0 extension is causing this issue, I refer you to the advice contained in msg #9 of Joomla legacy mode and Kunena . That advice should assist you in your task.
I'm very pleased to hear that this matter has been resolved.xpatman wrote: The photo sizes were 500x500 and under 40kb, they are basically the same as the others, and how are up and working fine
The only error message I was getting was in EDIT= =Warning: Invalid argument supplied for foreach() in components/com_kunena/lib/kunena.parser.php on line 571 and Today it is working.
