Question No Icons
15 years 5 months ago #98231 by easylivin
No Icons was created by easylivin
I am new at this and sure this is a stupid mistake but am lost as to how to correct it.
I am developing on localhost and everything is fine EXCEPT - I have no icons, no folder images, no new topic button or expand/collapse icons. The links are all there, just invisible.
I can see in Firebug that Backgroundurl("http://localhost/components/com_kunena/template/default/images/icons/folder_nonew.png") no-repeat scroll left center transparent - "failed to load given URL".
Makes perfect sense since something is missing.......
It SHOULD be:
("http://localhost/mydomain/components/com_kunena/template/default/images/icons/folder_nonew.png")
How do I correct this?
15 years 5 months ago #98251 by sozzled
Replied by sozzled on topic Re: No Icons
G'day, easylivin, and welcome to Kunena.
Please see the posting guidelines printed at the top of this page. It would help to know what environment we are discussing especially because we cannot actually see the problems that you mentioned (see also Support for PC-hosted websites (e.g. WAMP, XAMPP)
The problem may possibly be solved easily by reinstalling Kunena. On the other hand, the problem may also be solved by starting again and rebuilding your test site from scratch. Your problem could be a file permissions problem, or may be a problem with the operating system. Your website may not meet the minimum technical requirements for Kunena. You may have had a problem installing Kunena. I'm sorry but unless we know more about your situation there's not a lot of specific help we can give until we know what's causing the problem.
15 years 5 months ago #98252 by easylivin
Replied by easylivin on topic Re: No Icons
Hi sozzled,
Thanks for the reply and apologies for my ignorance.
Below the config details as I should have done the first time. Apologies.
htaccess: Missing | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 128M
Joomla default template details : jsn_epic_pro | author: JoomlaShine.com | version: 4.1.3 | creationdate: 05/03/2011
Third-party components: CommunityBuilder: The file doesn't exist comprofilej.xml !
15 years 5 months ago - 15 years 5 months ago #98261 by sozzled
Check folder/file permissions (see Securing Kunena ). Then I would suggest that you re-install K 1.6.4 (there is no need to uninstall what you have already).
Last edit: 15 years 5 months ago by sozzled.
15 years 5 months ago #98263 by easylivin
Thanks again sozzled. I will check all. Hope it's not too cold wherever you are in Aus. All my mates from home are complaining about it.
15 years 5 months ago #98366 by easylivin
Just for reference, I copied the entire com_kunena folder and all contents into the parent directory of my root (so created a components folder in htdocs and then copied com_kunena into components) and it fixed the problem.
This worked but I'm sure this is not a good workaround. Does anyone know why it would be looking for these files in htdocs and not the dbase name root (htdocs/mydomain)? Can I redirect it somehow?
