Question Why is my editor different?
15 years 6 months ago #96534 by pioneer6869
Is there a better Kunena editor for 1.5x Joomla. I have installed Kenuna on 1.6x and my Kunena editor is different than my install on 1.5x. Why the differennce? Differnet Joomla same Kunena...
forums.submitco.com
Wholesale Drug Testing.Com
Management
www.wholesaledrugtesting.com
15 years 6 months ago #96536 by sozzled
Replied by sozzled on topic Why is my editor different?
pioneer6869 wrote: Is there a better Kunena editor for 1.5x Joomla. I have installed Kenuna on 1.6x and my Kunena editor is different than my install on 1.5x. Why the differennce?
K 1.6 is different ... very different. See Kunena 1.6 - a moderator's view for an overview of the differences and read the release notes for more information.
pioneer6869 wrote: Differnet Joomla same Kunena...
I'm not sure what you mean. Different Joomla? How so?
Your site is using J! 1.6.x and you are using K 1.6.x. Am I right in assuming that you are using J! 1.6.3 and KI 1.6.4?
K 1.6.4 works well with J! 1.5.23 (see K 1.6 Technical Requirements ). You don't need J! 1.6 in order to run K 1.6 ... but ... if you want to use K 1.6 with K 1.6 you need J! 1.6.3 and K 1.6.4.
Is there a better editor? I think the answer is no. There will be differences in in editor features in K 2.0 (not yet available for public distribution at this time).
I hope this answers your questions.
15 years 5 months ago #96641 by pioneer6869
I am using k1.6.4 and j1.5.23... My editor in kunena doesnt look like the one im using right now. It doesnt hve the bold, italics and that top row of options. it has nothing there. just hs the emotes...
Management
15 years 5 months ago #96667 by sozzled
Your editor is "different" because your Joomla website has a problem. Please read msg #1 in If you are having problems with K 1.6, please read this first .
Your question has been asked hundreds of times before. We don't need another topic to answer the same question.
15 years 5 months ago #96697 by pioneer6869
I feel like a jerk for asking the question. I was just wondering why one was different than the other. Thanks....
Ill try and figure it out.
Management
15 years 5 months ago #96699 by sozzled
Don't worry. We are asked the same question in dozens of different ways but it's still the same question. The issue is not a Kunena issue; the issue is related to different software that people have installed on their sites. The solution is to look at those things and the tips given in msg #1 of If you are having problems with K 1.6, please read this first will address your problems ... in a general sense. Each person asking this question may have a different specific solution (depending on what other Joomla extensions they may happen to be using) and so the answer really lies in your hands.
We're not saying that you've done anything wrong. We're only trying to provide you with a way to fix your problems. However, to a large extent, most of these issues arise because of the fundamental issue, namely, Which came first? The template or the forum?
