Question Error with installation on Joomla site. Please help!
So I got a joomla site.. installed the kunena zipped file at extension manager.. everything goes well.. only it gives an error on the Dutch language pack installation.
It says: JInstaller: :Installeren: Kopiëren bestand /home/deb47108/domains/wheelblog.nl/public_html/administrator/components/com_kunena/language/nl-NL/nl-NL.com_kunena.ini naar /home/deb47108/domains/wheelblog.nl/public_html/administrator/language/nl-NL/nl-NL.com_kunena.ini mislukt (mislukt means failed)
What should I do about this? Permissions in FTP are set on 777 afaik.
Is this your first installation or you update or you come from J! 1.5.xx and then upgrade?
Also translate those your language texts to english, so we don't have to translate them is "Kopiëren bestand" is that like "Copy files"...?(google translator) And this failed from some reason...
Okey....... I just compare your nl-NL language package files to English and Finnish packages in the Kunena installation package... in your language are missing some files in admin packages? Can that be the reason for these our errors... and if yes, take the contact to nl-NL translator. I think this language will be next, what those admins will remove from package...
It's my first installation yes, but like i said.. everything is translated well except for the tabs like Recent Topics, Rules etc. Any chanse I can easily change those? And the ordering of those tabs..?
Bastard wrote: everything is translated well except for the tabs like Recent Topics, Rules etc. Any chanse I can easily change those? And the ordering of those tabs..?
Go to the (is this J! 1.5.xx) Menus -- Kunena Menu and change them to your language
This will be your easy way
