Question [Solved] How to invert profilebox and announcement?
I want the announcement shows above the profilebox.
Thanks in advance.
- Yup, you're correct. That's what I'd like to do.sozzled wrote: Let me see if I understand your question properly. You want to put the announcement above the profile box, is that correct?
- It was what I thought once I didn't see any option in the back-end. Do you have any idea which file controls it while we don't have this embedded option?You will need to change the Kunena source...
- It depends. Will this new version have such option in the back-end to invert profilebox/announcement positions, so we can opt to put above or below? It's a good suggestion for the next release or 2.0. I'll add in the Ideas for Kunena thread. ;0)...code but, I'm guessing, you don't want to have to change the source code when there's a a new release of Kunena, is that right?
- I know every new update, if I always want to have the latest Kunena, I'll need to change all again. In this case I need and I have a report off all lines and codes changed in the original code to accomplish my template and code.I'm also assuming that you might want your changes to work whenever there are new changes brought out in new versions of Kunena. Have I just about summarized everything you've asked for?
Do you remember the problems that you had when you stayed with K 1.6.0 for four or five months because of the changes that you made to Kunena? Is it really worth the hassle?
The project team is considering, for K 2.0, several fresh layout ideas for Kunena. Templates developed for K 1.6 will not be compatible with K 2.0 (just as templates developed for K 1.5 were not compatible with K 1.6 either). The incompatibility of templates between different versions of Kunena should come as not great surprise. Templates designed for J! 1.0 were not compatible with J! 1.5 - even if you say that they were compatible if you use "legacy mode", the templates themselves were basically incompatible - and J! 1.5 templates are totally incompatible with J! 1.6.
So, if you are prepared to accept all of these risks, I will then spend a bit of time searching through the Kunena source code to find where this is defined and then I will post the information for you. If, on the other hand, you don't think that the risks are really worth taking, merely for the sake of putting the announcement above the profile, then we won't have to bother ourselves.
There's actually an easier way to do this. You can create your own module position(s) for your Joomla site template, write a Joomla article that contains the "announcement" and put the announcement into that module position. This will allow you total flexibility in terms of what goes into the announcement. Simple solution and you don't have to change a single line of PHP code.
In sum, no need to spend a time seaching the code or changing the code for both of us!
Thanks a lot for your suggestion and help. Another topic solved. ;0)
