Question [Solved] K 1.6.4 - Alphabetical order issue.
15 years 6 months ago - 15 years 6 months ago #95596 by iLucato
Hi folks, I'm not sure if it is just happening with me, but I've upgraded from 1.6.0 to 1.6.4 and in the back-end, in the Joomla "Components" menu, Kunena Forum, isn't showing in its right position as it should follow the alphabetical order showing between J and L components. It is showing between A and C components as it was "B_kunena forum". It should be showing between J and L as normal "Kunena Forum".
Is it only with me or is anybody else getting the same menu order?
Last edit: 15 years 6 months ago by iLucato.
15 years 6 months ago #95619 by Matias
It's a bug in Joomla 1.5. Instead of using fixed name "Kunena" we are now using "COM_KUNENA" as menu item, which works both in J1.5 and J1.6. It gets translated but after sorting.
BTW: you have the same issue in other languages: items are not sorted alphabetically..
15 years 6 months ago #95628 by iLucato
Matias wrote: It's a bug in Joomla 1.5. Instead of using fixed name "Kunena" we are now using "COM_KUNENA" as menu item, which works both in J1.5 and J1.6. It gets translated but after sorting.
Thanks for the reply. Just to inform you, my Joomla back-end is in Portuguese-br and at Components menu all components are in alphabetical order, except for Kunena as using "Com_Kenena" may be falling between A and C as I said. :0)
15 years 6 months ago #95635 by Matias
In Finnish the order is the same as in English.. We just happen to have very different names for Joomla core components and they are all in very wrong order:
Mainospalkit
Kunena foorumi
Kontaktit
Uutissyötteet
Kyselyt
Etsi
Linkit
Same ordering in English.. Just almost alphabetical:
Banner
Kunena Forum
Contacts
Newsfeeds
Polls
Search
Web Links
So Joomla 1.5 orders items by their untranslated names..
15 years 6 months ago #95692 by iLucato
I See, thanks. Let's wait the Joomla team fix it. ;o)
Have a nice day.
