Question Can't login to frontpage during offline mode
15 years 7 months ago - 15 years 7 months ago #91773 by zeisse
after update Kunena to 1.6.3 when web page is in offline mode I can not login to front page (of course I'm using administrator account that is works on back-end).
Unfortunately on the same time I've updated also Community Builder to 1.4 and uddeIM private massage system to 2.3 and I don't know witch component (if issue is related to components) is responsible for this problem. After installation those components every thing was ok, so probably the problem was created during some components setups.
I've try switch off all those components but it dose't help.
This is what I get when trying to login:
(...)index.php?option=com_user&view=login&return=aH(...)
Any idea how to fix it?
Last edit: 15 years 7 months ago by zeisse.
15 years 7 months ago #91778 by zeisse
I've fixed it.
Problem was generated by menu. Position "home" was set to "registered only" and after set it to "unregistered" every thing woks fine.
