- Thank you received: 2
Question Mouseover Tooltips in boardcode
I host a fansite for a game called Rift and I'm trying to add a line of code to each forum post that would allow me to use a plugin for displaying a mouseover Tooltip. Here's an example:
rift.zam.com/enhancements.html
If you hover your mouse of the "Bull Rush", that's the tooltip I am trying to implement.
They even give an example of what code you need to put in your pages:
<script type="text/javascript" src=" common.allakhazam.com/shared/zampower.js "></script>
This code just needs to be somewhere in the page code, I just can't figure out where this code needs to go in order to have it activate on all forum posts.
Any help please?
You asked a similar question to this fourteen months ago and the answer has not changed.
The only essential difference between what was written fourteen months ago and today, is that K 1.6 is substantially altered in the source code. These changes notwithstanding, perhaps someone else in the community has made your idea work.
Thank you though for the quick reply and it appears I may have to find another solution, as that is quite a desirable feature for my fansite forum.
As for the 'Kiss your Kunena goodbye' how then do all the other 'popular' forums allow it?
Anyway, again, thanks.
Sorry. Good grief. So *all the popular* is kind of vague term... How about a list of BB's that DO support this type of include:
vBulletin
phpBB: 2.x.x - 2.x.x Mod Version | 3.0
Simple Machines Forum (SMF)
Invision Power Board (IPB)
WordPress Blog
PHP Nuke
MyBB
TikiWiki
YaBB
Drupal
PunBB
Dojo
Sure seems like a lot of *popular* BB's to me... and those are just the one's I know of.
All I was asking was if it was possible, and then why it wasn't with so many others where it is. *sigh*
I *wanted* to use Kunena because it claims to be 'the native joomla forum' ... which I'm sure it is, but with so much less functionality than at least 12 other forums, sadly, you've made it quite clear that any of the others is a much better solution, native or not, than Kunena.
Thanks Sozzled.
PS. Don't bother responding as I'm quite certain you'd just make some other snide comment. I doubt I'll be back to read it.
