Question Error when clicking to enlarge images
15 years 7 months ago #91216 by Mali85
First of all, sorry, my english is not that good as to explain this properly I think. I have this same problem when I had kunena 1.5 . You can click the images on the posts to enlarge but it doesnt work, all page becomes like white. I would like to know how to solve this problem and also if I can disable the option or that when you click on the image, to enlarge it, it will appear in a new window and not a preview on the same window
You can check one of my forum post with a picture here and try to click on in
portalsiam.com/index.php?option=com_kune...temid=22&lang=es#249
15 years 7 months ago #91251 by sozzled
All embedded images in Kunena are, by default, resized to fit into the area defined by your site template. If your site template is too "small" to display large images, Kunena will attempt to resize embedded images so that they will fit. The image is clickable; clicking the image runs a process to display the image at "full size". Do you really want to disable that feature?
If the lightbox effect doesn't work at your site it's probably because of some other extension that you have that is conflicting with the Javascript library used by the lightbox. See If you are having problems with K 1.6, please read this first .
Your Kunena menu is part-hidden by the site template that you are using. This seems to be a common problem with some JoomlArt templates. See Kunena Menu Gets Chopped- Sometimes
The following user(s) said Thank You: Mali85
15 years 7 months ago #91277 by Mali85
So how can I disable the feature then??
15 years 7 months ago #91279 by sozzled
You don't have the lightbox effect - that feature has been disabled by some other software that you've installed.
If you want to disable ability to click images, that's something completely different. I'm not sure how it's done, but you could look at the PHP source code for message.php in your Kunena template. I'm just guessing, though.
15 years 7 months ago #91543 by Mali85
ok got it! the problem was the component K2
