Question template for kunena and joomla not working now.
15 years 8 months ago #89020 by swordwebdesign
hey guys
im fairly new to joomla and the kunena forums.
I installed the forum last night and got registered users and everything it was working fine with my web template as well.
Well now it is not linking to the template at all.
Does anyone know the cause of this?
Any help would be much appreciated.
15 years 8 months ago #89029 by xillibit
What do you mean by :
"Well now it is not linking to the template at all." ?
15 years 8 months ago - 15 years 8 months ago #89040 by swordwebdesign
the website is
www.supra-tenetur.co.uk
go to the forum section on the left.
It appears that the tempalte is just not loading and the screen is all repositioned its really strange.
I have attached a screen shot to try and help out.
Last edit: 15 years 8 months ago by swordwebdesign.
15 years 8 months ago - 15 years 8 months ago #89043 by sozzled
Before we look at your website, can I please suggest that, if you want a quick response to questions posted in the Support category, you look carefully at the guidelines posted at the top of this page. To help us to better classify your topic "template for Kunena and Joomla not working now", I mean, what version of Joomla are we discussing, what version of Kunena are we discussing, and what changes have you made to your website that may have affected the interoperability of Kunena and Joomla in your case?
Your screenshot show that your website has not processed any CSS. This is usually indicative of a website that
(a) is underperforming and therefore unsuitable for running Joomla and/or Kunena; or
(b) does not meet the technical requirements for some other reason.
Can you please post your K 1.6 configuration report. Thank you.
15 years 8 months ago #89048 by swordwebdesign
Hello and thanks for the help so far.
Apologies for not posting my config file, but here it is.
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 24M | Max file upload: 10M
Joomla default template details : eve_online_lernvid.com | author: Juergen Koller | version: 1.0 | creationdate: 11.12.2009
last night i made no changes to website at all apart from installing kunena 1.6. This all worked fine for a few hours with no problems. Then i went to look at the site this morning and there it was not displaying in the forum section how it should.
15 years 8 months ago - 15 years 8 months ago #89054 by swordwebdesign
hi guys thanks for all the helpo but i have now found the root of the problem.
Many thanks for the help.
search engine freindly urls was on and it messed the site up lol
