- Thank you received: 9
Question split topic doesn't move subscriptions
Is it a known bug?
It's not a known "bug" as such. That's just how topic subscriptions work.
If you split a topic in the middle and therefore you create a new one, the subscriptions should be moved, at least for the people who participated in the discussion after the post that is now a new thread.
If you have a topic A and you split it into A - that contains the original first post - and B, then only the subscriptions for the new category A will survive.
On the other hand, if you have topics A, B, C, D, E ... etc., and people have subscribed to each of them, individually, and you merge them all into a new category (X, say) then some or all the subscriptions may survive the merge.
Splitting and merging is tricky as far as subscriptions are concerned. I haven't spent enough time testing all there is to know about them. Perhaps someone else knows more than I do.
When you "subscribe" you actually tag a specific message record, one that defines the start of a topic. You can check this for yourself if you look at the jos_kunena_subscriptions table in the database.
Anyway, thanks for your time!
I guess that I have to move/copy subscriptions manually every time that I split a topic
