Question Kunena Categories/Topics will not load
15 years 8 months ago #87468 by ajackson713
None of my forum topics will load. The index page (as well as the rest of the menu items) load just fine, but if you click on a category or topic it will not load. I have tried the following so far:
1) disabling all plugins and modules - No success
2) reinstalling Kunena - No Success
3) resetting default settings - No Success
4) using generic joomla themes - No Success
3) changing settings that may cause problem - No success
I am by no means a guru so it is most likely something that I did on the backend to cause this issue. It was working fine yesterday. Any help will be greatly appreciated. my site is www.fishthecountry.com
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Disabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 50000 seconds | Max execution memory: 40M | Max file upload: 20M
Joomla default template details : rt_kinetic_j15 | author: RocketTheme, LLC | version: 1.5.0 | creationdate: February 1, 2010
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.4) | Jomsocial: Disabled or not installed | UddeIm: Disabled or not installed
15 years 8 months ago #87479 by GoremanX
Please disable the legacy mode plugin in your Joomla plugins. Kunena will not run as long as that plugin is enabled.
www.friendlyphotozone.com
15 years 8 months ago #87492 by ajackson713
Thanks for your reply GoremanX. I disabled the legacy plugin but the problem still persists. Any other tips?
15 years 8 months ago - 15 years 8 months ago #87500 by GoremanX
if you have any kind of caching enabled (whether on the server or your browser), you might need to either flush it or wait until it expires.
Also, the RT Kinetic template has been updated to version 1.5.6 by now. There may be a conflict between your template and Kunena.
Last edit: 15 years 8 months ago by GoremanX.
15 years 8 months ago #87502 by sozzled
G'day, ajackson713, and welcome to Kunena.
I wouldn't go as far as saying that K 1.6 won't work with legacy mode - I would merely point to the topic Joomla legacy mode and Kunena and respectfully suggest that, in my very humble opinion, no-one in their right mind should be running J! 1.5.22 with the System - Legacy plugin enabled. But that's just my opinion. ;)
What appears to be confuzzled in your case is your use of Joomla SEO. Again, most respectfully, I would suggest that you very carefully and very thoroughly examine the Search Engine Optimisation (SEO) guide in the Wiki. But whether or not this fixes - it remains to be seen if it does - it's a good idea to get your Joomla configuration "juiced up" :)
The one key piece of information that you omitted from your question was this: when you press any category you get the browser message
The page isn't redirecting properly
Firefox has detected that the server is redirecting the request for this address in a way that will never complete
* This problem can sometimes be caused by disabling or refusing to accept cookies.
If we had known that this was the case then I would have suggested that you read the fascinating topic [Merged topic] Firefox has detected that the server is redirecting the request for this address ... ... and that is where I believe you will find the answers to your question. I hope this helps.
15 years 8 months ago #87531 by ajackson713
I turned off the SEO and everything seems to be working fine now. Thanks for the help guys.
Time to create page: 0.159 seconds
