Question Smileys (not working when adjacent to a word)
15 years 9 months ago - 15 years 9 months ago #87432 by Kymmy
The smileys do not tend to work when adjacent to another character:) <<example
yet in it's own space it works :) <<2nd example
Is there any way of changing the code so that it doesn't need the space (yes I know it can then alter smiley text within wording but astute use of the smiley text can prevent most instances.
ThanX Kymmy
Kunena = 1.6.3
Last edit: 15 years 9 months ago by Kymmy.
15 years 8 months ago #87473 by sozzled
I don't think this has ever worked in a previous version of Kunena (in they way that you've described it) but I could be wrong. I am fairly sure that [some/all?] smiley BBcodes require whitespace between them or they're treated as plain text.
15 years 8 months ago #87503 by Kymmy
Kunena is one of the few where it works like that.. Will have to go for a dive into the code to see what's happening..
TnX anyway :D
15 years 8 months ago #87506 by sozzled
Most of the time I press the emote buttons and let Kunena insert them in the "appropriate manner" :pinch: :pinch: :)
15 years 8 months ago #87516 by Kymmy
Yep but it relies on you manually putting a space in before the emoticon, perhaps then if I can't do anything with the parsing it might be an option to include the space before and not after the emoticon in the coding ;)
15 years 8 months ago #87519 by sozzled
No, I just clicked the emoticon buttons and they inserted whitespace between the BBcode. I didn't manually insert anything.
