Question Login before Kunena forum
this is my first posting and today I am new registered. I work still with Joomla 1.5.20 and I have download your newest Kunena version.
But now my question - before the Kunena index-side (home-side) shall appear a login because only legitimate users shall see (enter) the forum. Therefore I have download your Kunena Login modul
www.kunena.org/ked/modules/94
Only - which modul do you use on your website? I want the same login with the addition create an account which I have today used to register here. In the mentioned modul I find no create an account. I would like though, that users can create an account consisting of password and username itself but the final activation should be done by the admin. Please have understanding for my questions but I am a beginner and have nobody who help me.
Hope that my question is on the correct place and my English is quite understandable. I would be very pleased for your help. Thank you very much in advance. Kind regards, sepp
Thank you for your very good questions. I hope my answers will be just as good.
You do not need the Kunena Login module; it is optional. You can use whatever login module you already have; you can use the standard Joomla login module, if you like!
The most important point that we need to make is the Kunena does not handle user registration. Kunena does not create the Joomla user accounts when your users join your website. There is no Kunena registration function.
Joomla handles user registration. You can, if you like, install other components to assist the Joomla registration process: components like JomSocial or Community Builder, for example.
sepp wrote:
Unfortunately, Joomla does not have the means to do that. In Joomla you can either allow everyone to register or you allow no-one to register. There is no other option where users can start the registration process but you, as the administrator, finish it off for them. However, if you want your users to register but require your approval to complete their registration, you can do this with a Joomla extension (like Community Builder or Jomsocial). As I have already written earlier, Kunena does not have a user registration function.I would like though, that users can create an account consisting of password and username itself but the final activation should be done by the admin.
thank you very much for your reply. Today I have now installed Kunena and the installing on my Joomla-version 1.5.20 was nearly without problems. Have uploaded the zip-file and a little bit tried.
But - if I click on configuration report I get the message:
Please can you tell me what this means or what can I do that the message not more appears.Fatal error: Call to a member function data () on a non-object in .../administrator/components/com_kunena/admin.kunena.php on line 3212
I have installed a blank_template. The place in my standard_template was to small (the blank_template was not from me, I could it never). The allocation that Kunena to be loaded into the blank_template works, also fine. But certain links such announcements are now loaded into my standard_template and unfortunately not into the blank_template. Is it possible to solve the problem or has the blank_template mistakes. With other words Kunena shall appear in separate side. Do you have perhaps blank_template to download? If yes I use yours.
I would be very pleased if you can help me.
Kind regards, sepp
What kunena version do you have installed ?
I have installed the newest Kunena version 1.6.3. Tomorrow I bring more information and I can upload a screenshot(s) if you agree. Well the topic regarding the blank_template is solved. I haven't choosen all menus for the allocation into the blank_template. It works! All links from Kunena are showing (loaded) now into the blank_template (separate side). Kind regards, sepp
I have reinstalled Kunena but the error message is again. I have created a new user in the joomla backend on level registered (please look user_joomla.gif). But in the Kunena backend user menu doesn't appear this user. Only the admin named board_mod (file user_kunena.gif). Must it not be displayed in Kunena backend all users who are also in the user menu of the joomla backend? Whether logged in or not logged in?
Does the error message which I have mentioned yesterday along with this effect? Must I upgrade on the joomla version 1.5.22? I'd like your Kunena and the features are phantastic. Only the problem, otherwise everything would be perfect. Have other users never received the error message?
