Question 1.6.3 weird little things
15 years 9 months ago #85321 by mabras
Hello everybody,
I have just moved to the new 1.6.3 version (on Joomla 1.5.22)
Kunena is excellent as usual, but here I found a few minor errors:
in the search page
in the latest topics header
in the backend (frontpage and plugin settings)
... is everything OK with my install?
How can I fix at least the search page?
Thanks!!
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 64M | Max file upload: 25M
Joomla default template details : psiconet02 | author: Maurizio Brasini | version: 1.0 | creationdate: 2011-02-08
Kunena default template details : Argent(RC3 - stable) | author: Gonzaunit | version: 1.6.0 | creationdate: 2010-08-20
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.3.1) | Jomsocial: Disabled or not installed | UddeIm: Disabled or not installed
Third-party SEF components: sh404sef: Disabled or not installed | ARTIO JoomSEF: Installed (Version : 3.7.6) | AceSEF: Disabled or not installed
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Enabled (Version : 1.6.2) | Kunena Search: Enabled (Version : 1.6.2) | My Kunena Forum Menu: Disabled or not installed | My Kunena Forum Posts: Disabled or not installed
15 years 9 months ago #85325 by sozzled
You will only see the display (shown in the first picture) if you are running Internet Explorer 7 in a narrow window. On my screen, running 1920px (wide) x 1080px high, I do not see this problem in IE7. I also do not see this problem in Firefox or Google Chrome.
What browser are you using and what is the size of the browser window (in pixel) that you are looking at your page with?
For the other problems you have reported in this topic, please use different topics. We like to keep subject per topic. Thank you.
The following user(s) said Thank You: mabras
15 years 9 months ago #85328 by mabras
Hi and thank you for replying!
Sorry, I thougt that all errors were related to a same install problem.
As for the search facility, I am using Explorer 8.0.76 (not 7), same screen as yours, and a template that exploits the full size of the screen.
But you are right: the problem does not show with Firefox and Chrome.
So...? what could it be? and how to fix it?
Thank you very much
mabras
15 years 9 months ago #85340 by sozzled
You will only see the problem if you use IE8"compatibility mode" - compatibility mode makes IE8 function like IE7. Turn off "compatibility mode". End of problem
15 years 9 months ago #85344 by mabras
You were right, thanks it's a but for IE7 and compatibility mode!
mabras
Time to create page: 0.150 seconds
