Question First impression/questions/bugs
- Forumpojken
I have now Installed Joomla 1.5 and Kunena 1.6.2 and used it for a while. I have some questions that I hope someone can answer:
If I creat a thread called "hey" and someone replys to it there will be two links pointing to the same thread:
/forum/section/62-hey.html and /forum/section/62-re-hey.html. This must be a bug.. or?
There are no settings on how big you want the avatars to be? I mean how big they are shown in pixels?
Shouldnt there be an "If user dont pick an avatar, Use default avatar? [yes/no]" option? I do not want to show that default image.. I have almost removed it by making the pic 1x1 pixel though
Are there any plugin to make Kunena work with Tapatalk?
Are there any plugin/extension that gives the users more settings? Users wants to change more things for themselfs ie: Number
of messages shown / page + more stuff..
How do I change settings for the signatur? I want to limit the users to only add ONE image of MAX 100x100pixels. How do I do that?
If one writes a new thread and forgets to write a topic, then the hole message dissapears when you hit "Send"! (This happens sometimes in some browsers.. Java failure?
If I press "quick reply" and starts to write a reply.. But then needs to add urls or whatever and wants to go to the "big editor" and just hits "Reply" instead.. ALL text I have written is gone.. very annoying.. the text should be copied into the new editor!
How do I write an "announcement" like you have here? ("Kunena turns 2!...")
Is there really no wysiwyg editor for Kunena?
All your questions have been answered elsewhere in the forum. Please use the search facility.
- Forumpojken
All I found was lots of talk about wysiwyg editor, thats why I asked "Is there really no wysiwyg editor for Kunena?" More like in WHY are there not any? Is it on its way?
I also found some special hacks to change Avatar-size.. But nothing in any normal backend config.
Maybe atleast you can answer to this:
I guess you know the answer to that one in your sleep?
I'll try to do some more searching...
Edit:
Ive now searched for 30mins without any luck! Didnt find any good answers except about Tapatalk.
I'll guess I'll wait and see if anyone else can help me :ohmy:
- Forumpojken
- Forumpojken
These I still needs help with though:
I see this on lots of other boards.. Even this one so I guess its supposed to be like this??.. but why? Doesnt google etc dislike multiple different links that point to the exact same content?If I creat a thread called "hey" and someone replys to it there will be two links pointing to the same thread:
Tried to search this forum but didnt find anythingAre there any plugin/extension that gives the users more settings? Users wants to change more things for themselfs ie: Number
This really sucks.. I have already users complaining about this. In other forums (vBulletin) you can change from "quick-edit" to "full editor" without loosing what you already typed.If I press "quick reply" and starts to write a reply.. But then needs to add urls or whatever and wants to go to the "big editor" and just hits "Reply" instead.. ALL text I have written is gone.. very annoying.. the text should be copied into the new editor!
Thanks in advance!
