Question [SOLVED] Stack overflow error on Line:1 in Internet Explorer and Firefox does not submit posts.
15 years 9 months ago - 15 years 6 months ago #83177 by tread77
Last edit: 15 years 6 months ago by tread77.
15 years 6 months ago #96161 by tread77
Update:
For anyone looking for help here. This was a mootools conflict issue due to the template I was using. Make sure anyone you purchase a template from, really supports their product. Also try to use gallery and other tools from the template maker. Kunena works well if your template is quality.
I switched from joomla2you template to a Yootheme template and haven't had any issues since.
15 years 6 months ago #96233 by sozzled
Thank you for your update about this issue. You started this topic before we had written the guide to solving such problems (which is referred to in msg #1 of If you are having problems with K 1.6, please read this first . I've linked your topic to the general solution topic for the benefit of others. :)
