- Thank you received: 6
Question Bullet points in lists mising?
Is the bullet point lists ever going to get solved..? Just that at the moment the .column ul li in joomla's template.css is overwritten by a Background: none statement in Kunena.foum-min.css
Without rewriting the bbcode and allocate it a new class (a bit beyond my skills) it's upto the developers..
So the developing team is there possibility of a bit of feedback on this problem
TnX Kymmy
A simple solution is to just add a statement to the css file to include a bulletpoint for that div class
So I added the following that now works
Obviously the url will be dependant on where you have the bullet.gif file but other than that it works..
Again the URL will be pointing to where-ever you have you bullet.gif file (normally found within your joomla template images folder
It is no wonder you were confused. It is not surprising that your search of your question gave you inconclusive advice. That's why we like to keep the topics confined to a single issue ... one issue per topic. Helps everyone better that way!
Our job here, in forum moderation, is to keep things as on-topic as possible in order to help other people looking for answers. A lot of people forget that when they create these broad-ranging topic subjects like "I have a few questions ... " or "Help me, please". Sooner or later we have to do something to bring the matters to a satisfactory resolution. Sometimes the only way we can achieve that is to lock the topic.
BTW, sorry for my off-topic remarks in your topic!
