Kunena 7.0.8 Released
Question An...interesting question pertaining to profiles in Kunena
However, ,the reason I thought you could change the default directory is because if you notice what it says in Kunenas backend is:
In = My Site>Administrator>Kunena Forums>Forum Configuration>Avatars
Use Avatars Gallery? Yes or No: Set to Yes if you want registered users to be able to choose an avatar from a gallery you provide (/media/kunena/avatars/gallery).
from a gallery you provide - makes me assume it can be changed. I could be wrong though.
All I did was:
Open FileZilla FTP Client>>Created a New Directory in **********/home/public_html/media/kunena/avatars/gallery for each of my Avatar Gallery Categories, and copy/paste the original Avatar images from my Avatar Gallery Directories into their appropriate folders in the media/kunena/avatars/gallery folders to create the sub-folders you mentioned. Then they simply showed up as sub-folders in the user profiles.
Simple stuff...Thank you again sozzled, as I would have never thought of the idea if you had not said;
From a gallery that you provide" means a subfolder of ../media/kunena/avatars/gallery
