Question Width problem in posts
15 years 10 months ago - 15 years 10 months ago #79207 by gregpab
Hello, I am relatively new in Joomla and Kunena.
I have installed Kunena and CB and all went fine.
While I was testing Kunena forum and other extensions with two testing users which I created, I saw that there was a problem in one of the users. Because my English are not excellent I attach two PrtScrs to show you the problem. Please help.
EDIT: After a few hours of testing I managed to reproduce the problem and to understand the origin of it. So, when I change a registered user to Moderator from "Moderation"-->"Change moderation settings for this user" and I set the value to "Yes" I have this width problem!!!
Last edit: 15 years 10 months ago by gregpab.
15 years 10 months ago #79455 by gregpab
Replied by gregpab on topic Re: Width problem in posts
:unsure:
:blush:
:whistle:
15 years 10 months ago #79459 by 810
Replied by 810 on topic Re: Width problem in posts
Hi, can you make me a user account with an moderation status. also can you add here a Kunena Report Configuration Settings.
Regards 810
15 years 10 months ago - 15 years 10 months ago #79461 by gregpab
htaccess: Exists | PHP environment: Max execution time: 10 seconds | Max execution memory: 64M | Max file upload: 2M
Joomla default template details : yoo_expo | author: YOOtheme | version: 5.5.2 | creationdate: December 2010
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.3.1) | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.2)
Yes, I could provide a test acount to see the problem. Tell me how to send you the password.
I created a test user and I gave him Admin rights and the problem was not there!
While I was testing the new test user I found that:
when I turn the user front-end language into Greek and if the user is also Administrator the problem appears.
If any of the above two factors is missing the width is again normal.
*Of course you have to re-login every time.
15 years 10 months ago #79462 by 810
you can send me a pm.
15 years 10 months ago #79463 by gregpab
ok, I sent a pm
Time to create page: 0.184 seconds
