Question Won't Upload Attachments
15 years 10 months ago #78794 by mattc908
So basically I installed Kunena and I enabled to attach files to there post. Well when I click on choose file for the attachments, it pulls up the browser, which I click the file than it does nothing, like it keeps the attachment form empty, I can do this 100 times and its as if it never selects the file I choose. I can't upload attachments.
15 years 10 months ago #78808 by Mortti
Replied by Mortti on topic Re: Won't Upload Attachments
This category is for Kunena version 1.6 issues only. For a faster response, please make sure you include your K 1.6 configuration settings report in your posts.
Something about Configuration Report: docs.kunena.org/index.php/K_1.6_Configuration_Report
15 years 10 months ago #78836 by mattc908
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 99M | Max file upload: 64M
Joomla default template details : rt_panacea_j15 | author: RocketTheme, LLC | version: 1.5.0 | creationdate: July 2, 2010
15 years 10 months ago #78837 by mattc908
I realize Mootools system upgrade is disabled, but it has to be or it messes with my theme and other parts of the website, I had an older install with it disabled and it worked fine.
15 years 10 months ago #78857 by mattc908
Problem Fixed, another plugin was messing with kunena.
15 years 10 months ago #78859 by sozzled
mattc: For the sake of completeness (and for the benefit of others who might be in your situation), what was the name of the other software that was "messing with Kunena"?
The following user(s) said Thank You: mattc908
Time to create page: 0.147 seconds
