Question Recent topics not showing...
Everything works OK but when I go to the Recent Topics page I don't see any topics...
Could someone advise were to look for the problem??
Thanks!
Configuration report:
Joomla default template details : gk_quay | author: Robert Gavick - GavickPro | version: 1.1.0 | creationdate: 10/11/2009
<div>Check back soon!</div>enablerss 1 enablepdf 1 threads_per_page 20 messages_per_page 6 messages_per_page_search 15 showhistory 1 historylimit 6 shownew 1 jmambot 0 disemoticons 0 template default showannouncement 1 avataroncat 0 catimagepath category_images/ showchildcaticon 1 annmodid 62 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 1 askemail 0 showemail 0 showuserstats 1 showkarma 1 useredit 1 useredittime 0 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 1 allowfavorites 1 maxsubject 50 maxsig 300 regonly 0 changename 0 pubwrite 0 floodprotection 0 mailmod 0 mailadmin 0 captcha 0 mailfull 1 allowavatar 1 allowavatarupload 1 allowavatargallery 1 avatarquality 65 avatarsize 2048 allowimageupload 0 allowimageregupload 1 imageheight 800 imagewidth 800 imagesize 150 allowfileupload 0 allowfileregupload 0 filetypes txt,rtf,pdf,zip,tar.gz,tgz,tar.bz2 filesize 120 showranking 1 rankimages 1 avatar_src fb fb_profile fb pm_component no userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 1 userlist_username 1 userlist_posts 1 userlist_karma 1 userlist_email 0 userlist_usertype 0 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 1 latestcategory 3 showstats 1 showwhoisonline 1 showgenstats 1 showpopuserstats 1 popusercount 5 showpopsubjectstats 1 popsubjectcount 5 usernamechange 0 rules_infb 1 rules_cid 1 help_infb 1 help_cid 1 showspoilertag 1 showvideotag 1 showebaytag 1 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 1 ebaylanguagecode en-us fbsessiontimeout 1800 highlightcode 0 rss_type topic rss_timelimit week rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 0 rss_old_titles 1 rss_cache 900 fbdefaultpage recent default_sort asc alphauserpointsnumchars 10 sef 1 sefcats 0 sefutf8 0 showimgforguest 1 showfileforguest 0 pollnboptions 5 pollallowvoteone 1 pollenabled 1 poppollscount 5 showpoppollstats 1 polltimebtvotes 00:15:00 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 50 ordering_system mesid post_dateformat datetime_today post_dateformat_hover ago hide_ip 1 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 50 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty integration_access auto integration_login jomsocial integration_avatar jomsocial integration_profile jomsocial integration_private none integration_activity jomsocial boxghostmessage 0 userdeletetmessage 0 latestcategory_in 1 topicicons 1 onlineusers 1 debug 0 catsautosubscribed 0 showbannedreason 0 version_check 1 showthankyou 1 showpopthankyoustats 1 popthankscount 5 mod_see_deleted 0 bbcode_img_secure text listcat_show_moderators 1 lightbox 1 activity_limit 0
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 1.8.10) | UddeIm: Disabled or not installed
Have you tried with the standard Kunena template, to eliminate the possibility its an issue with your pre-Kunena 1.6 template? Looking through these posts that's THE most common issue discussed.Joomla default template details : gk_quay | author: Robert Gavick - GavickPro | version: 1.1.0 | creationdate: 10/11/2009
I'm pretty sure you should have Mootools enabled as well, or at least the upgrade.Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Disabled
When I go to 'Kunena --> Template Manager' the selected template is 'Blue Eagle (default)'...Have you tried with the standard Kunena template, to eliminate the possibility its an issue with your pre-Kunena 1.6 template? Looking through these posts that's THE most common issue discussed.
I enabled the MooTools upgrade but that didn't fix the problem...I'm pretty sure you should have Mootools enabled as well, or at least the upgrade.
Found it..!
It's a very basic thing I managed to ignore.....
In the 'Kunena Forum --> Configuration --> Frontend' page you have the option 'Category List in Recent Topics' which gives you the ability to define the categories which will be used to populate the recent topics page...
I you choose a category with no topics (like I did..!!!!) you'll get no results on the recent topics page..!!
The default selection, which I'm using now is 'Show All Categories'!
It's that simple..!
Regards!!!
If you change things and your forum doesn't work for you the way that it used to work, revert your settings back to their default values. K 1.6 makes it possible to do this with a single mouse-click.
