Important about menu problem
15 years 11 months ago #72334 by thiru_ch
about menu problem was created by thiru_ch
Hi i am new to this forum.
i had installed kunena forum in my site.
when i had set a menu option to kunena index then it show an error that the page is not properly linked and if i reset the menu option to recent topics then it working but when i clicked on category is not showing any messages.
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 10M
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Enabled (Version : 1.6.0-RC2) | Kunena Search: Disabled or not installed | My Kunena Forum Menu: Disabled or not installed
Modules: Kunena Latest: Enabled (Version : 1.6.0-RC2) | Kunena Stats: Disabled or not installed | Kunena Login: Enabled (Version : 1.6.0-RC2)
help will be appreciated.
15 years 11 months ago #72341 by sozzled
thiru_ch wrote: I had set a menu option to kunena index then it show an error that the page is not properly linked and if i reset the menu option to recent topics then it working but when i clicked on category is not showing any messages.
What was the exact error message, please?
I visited your website. I clicked topics, categories and they all worked. Can you show us (perhaps with a picture) exactly what is the problem, please?
Everything seems to be working well on your website.
While we have your attention, I notice that you have legacy mode enabled on your website. Please read the important information about Legacy mode in the Wiki and please do something to eliminate your dependence on this. Please do this now before you have problems in the future. Thank you.
15 years 11 months ago - 15 years 11 months ago #72365 by thiru_ch
Replied by thiru_ch on topic About kunena menu
i want to create different menu options for different sections. when i selected a menu option it displays the section properly but the kunena menu is not displaying.
is it possible to create menu options like that.
images of my site are
see the diffrence: u may observe the difference that in the above image kunena menu is displaying but in the below when i seleced the menu(student corner) it is not displaying.
how to rectify ? i need help
Last edit: 15 years 11 months ago by thiru_ch.
15 years 11 months ago #72392 by xillibit
Replied by xillibit on topic About kunena menu
Can-you put here please your Kunena report configuration ?
Can-you try to re-create the kunena menu by using the function in kunena configuration panel
15 years 11 months ago #72681 by thiru_ch
hi i am sending the config. report of kunena.
15 years 11 months ago #72828 by thiru_ch
Thank you for you reply. here i am sending the images of my site
i created different menu options for different sections of my forum.
when i selected option the kunena menu is not appearing in my site.
when i clicked Forum menu the image is as follows.
when i clicked Student Corner i am getting the following in which the kunena menu is not appearing.
help please..
Time to create page: 0.168 seconds
