Kunena 7.0.8 Released
Important Smilies not showing!
15 years 9 months ago - 15 years 9 months ago #70718 by FreeThinker
Hi all
first of all this new version rocks...but i'm having a minor issue with a forum on one of my websites..
..it is not showing the smilies!
Last edit: 15 years 9 months ago by FreeThinker.
15 years 9 months ago #70721 by fxstein
Replied by fxstein on topic Re: Smilies not showing!
Would you mind posting your config report and possible a test account?
You can do that like:
[confidential]username,password[/confidential]
I'd like to see that new topic page. Thx!
The following user(s) said Thank You: FreeThinker
15 years 9 months ago - 15 years 9 months ago #70740 by FreeThinker
Tryed to send you the info requested thru PM...but service (jomsocial messaging service) is not working ok :dry:
am sending u in
15 years 9 months ago #70747 by xillibit
Replied by xillibit on topic Re: Smilies not showing!
I advise you to disable legacy mode and safe mode too, if it's possible.
Do you have checked that the smilies are right here and the permissions allow the smilies to be read by everyone ?
15 years 9 months ago #70822 by FreeThinker
Thanks xillibit for the reply :)
The smilies are on the templates folder
(/public_html/components/com_kunena/template/joomlana_dark/images/emoticons)
...and also appear ok and visible in kunena backend.
About the permissions....
Folders (images \ emotions => are 0755
...and the smilies images => are 0644
Regarding the Legacy mode, i intend to turn it off...but have to eliminate and/or upgrade some features (mods; plg).
*The safe mode I do not know where's it at! :blush: :P
Cheers
15 years 9 months ago - 15 years 9 months ago #70832 by fxstein
The smilies are in the wrong folder.
The template your are using is only overriding very few styles of default and is using everything else from default, including the smilies:
www.mdracers.com/components/com_kunena/t...oticons/applause.gif
this is the path to the very first smilie in the toolbar, and the file simply does not exist.
This might be an issue with smilie management in combination with custom but only partial templates that leverage default for the vast majority of code and images. In this case the dark New topic bbcode editor is still running the default editor that points the smilie bar top the default template location.
We need to find a way around that.
A quick fix is to copy the smilies form the custom template location into the default template location.
@xilibit - would you mind creating a tracker for this issue? Thx!
Last edit: 15 years 9 months ago by fxstein.
