- Thank you received: 1
Kunena 7.0.8 Released
Question Resizing Signature Graphic
I just put my signature on my forums and it is a graphic one, link to my photobucket, and the image is considerably smaller than Im used to in forums. Ive hunted thru the config and Ive searched thru the forums.
Is there a way to make the default graphic image in your signature larger? Thank you for your help
What if someone wanted to use an image that was 3500 pixels wide (and it wasn't automatically resized)? Would you want that to happen? There has to be a limit, somewhere. The limit is the width of the space assigned to display your Joomla component.
Thanx for the help!
If you want to use an image in a user's signature that was as big as 450 pixels wide and 600 pixels high, that wouldn't leave much room on the screen for writing much of a message, now would it? Think about what you might be asking for. 600 pixels high (even 500 pixels high) is over half the screen height for some users' monitors. 150 pixels high is plenty big enough for an image used in a user's signature.
How big an image do you have and how small is it when it's resized?
To recap, without knowing anything about the dimensions of your site template, I am guessing that it's not wide enough to allow the full-size display of images of the size that you want within a web-based discussion forum, like Kunena. It all comes down to what you really need. I'm only guessing here because I haven't seen your website but my generalised answer is to use a template that has some width to it.
The template that I am using is rockettheme / zeyphr (I believe)
As far as the whole 450 x 600 of course that would be incredibly LARGE I was using
it as an example not for actuality.
I had a 350 x 130 image that I used in everyone elses forums, when it did not
look right in mine I resized it to 400 x 150 with no change on the forum
signature size.
The image in the forums at least for me is 267 x 100.
My main question: Is there a way to manually change the resize option?
OR do I have to work with what I have, change my template, resize the component features....
I appreaciate your help in this manner I hope this is more of a specific question format.
try to add this rule to your main Joomla template css file
#Kunena div.kmsgsignature img {
max-height: 150px !important;
Hope this helps
Regards
